Pentium 66 MHz socket 4 system
Reply 20 of 31, by Ponjiayulady
Pentium 66Mhz performance test
    68.57 KiB
    cpumark
    89.58 KiB
    Pi 1M
    83.49 KiB
    sisoft sandra
Reply 21 of 31, by Ponjiayulady
Socket 4 Pentium Overdrive original Box
1.14 MiB
POD 133Mhz Box
Test
62.57 KiB
cpumark
104.33 KiB
Pi 1M
Reply 25 of 31, by mpe
foil_fresh wrote on 2020-03-25, 01:36:
regarding the fdiv bug. does it prevent anything "normal" from happening? cause any instability? if so, why use it?
The FPU is less accurate. You get wrong results when you divide certain numbers. Won't affect stability, but it has historical significance - a sort of curiosity.
Intel ran expensive chip replacement program and most chip got replaced and scrapped. That's why those original chips with FDIV bug are way less common.
Blog|NexGen 586|S4
Reply 26 of 31, by mpe
The performance of this system has been great so far.
I was thinking about how to tune it even further. Then I found a datasheet of the clock generator (MX8315) with undocumented 80 MHz FSB option.
72.87 KiB
Obviously, 80 MHz is is too much for old 5V 60/66 MHz CPUs. However, it surprisingly works with more efficient PODP5V133. The 160 MHz CPU, 80 MHz FSB and generous 2MB L2 cache really gives this system wings. A Socket 4 system with asynchronous L2 can now compete even with much more modern 150/166 MHz Socket 7 systems with Intel Triton chipset. Even with more conservative 3-2-2-2 L2 timings.
Some results:
7.48 KiB
437.66 KiB
307.05 KiB
Blog|NexGen 586|S4
Reply 27 of 31, by Anonymous Coward
Cool. I have an Acer J3 motherboard with dual Socket4 CPU card. It originally came with P60s but I have dual POD5V133s for it. This system also has an 80mHz FSB setting, but I've always been a little nervous about testing it out.
Reply 28 of 31, by H3nrik V!
Anonymous Coward wrote on 2020-04-19, 09:15:
Is SMP possible with POD's? Wasn't that option removed?
Reply 29 of 31, by mpe
The on- chip APIC only came with P54C. However, there were 2- or more way systems before that (even 486). Just vendors had to use their own glue logic to handle interrupt, maintain cache coherency, etc. They could also use external i82489DX which Intel provided long before P90.
Also EISA systems have APIC alreeady in the chipset already which might be the case of the Acer system
Blog|NexGen 586|S4
Reply 30 of 31, by feipoa
Interesting. I have an Acer socket 4 motherboard setup with a POD5V133 and a Voodoo1 but I don't think I bothered to look for an undocumented 80 MHz setting. Something else for the list I guess.
