First post, by wbahnassi
Hi guys, I have an HP Z400 workstation with a Xeon W3520 installed. I want to juice it out a bit more, so I found that the Xeon W3690 seems to be the most powerful LGA1366 processor. But I'm not sure the mobo could take it. I mean the socket is correct, but what about power/heat/BIOS? Especially that according to the HP z400 official specs, it was not one of the options:
https://support.hp.com/ca-en/document/c01709672
I don't know if they didn't list it because it wasn't out at the time or because the machine can't handle it. Any insights on whether I should take the chance or even better alternatives? I don't mind buying it anyways as long as it doesn't burn my mobo during testing 😀 As I like this machine a lot thanks to its ability to run a fully native DOS setup with sound card and floppy drives, while it is still able to push Windows 11!
Cheers!
Reply 1 of 5, by pentiumspeed
No problem handling this processor.
Just in case, do you have same type of heatsink like this? This is 3 heat pipes type and is for this 130W processor.
https://www.ebay.ca/itm/266030286219?hash=ite … ABk9SR-yc_ezIYQ
There is another heatsink but this is 2 heatpipes and will not handle more than 80W of heat at peak.
Cheers,
Great Northern aka Canada.
Reply 2 of 5, by wbahnassi
pentiumspeed wrote on 2023-02-12, 18:08:
I have the same heatsink as the eBay listing. Same part number. So this one should be sufficient, right?
1.5 MiB
Reply 4 of 5, by wbahnassi
Got the new processor installed. Man, that's quite a perf boost! Really happy with how Windows 11 now performs. Video editing is about 1.5x faster too on a single thread. I must test perf on DOS to see how slow this guy goes.. the previous processor was slowing down to a 386 DX 33Mhz machine... Gotta see how well this guy does.
Cheers!
Reply 5 of 5, by Errius
One thing to watch out for with these old systems is the CPU's power saving features that cause it to throttle down when 'inactive'.
If you're doing a lot of Windows Explorer type activity (saving/renaming/listing/moving/etc files) the CPU speed will go up/down chaotically and will give you an unpleasant experience.
Go into BIOS and disable EIST, C1E and C-states. Your machine will be much snappier. (But will also consume more power.)
Is this too much voodoo?
