First post, by wbahnassi
- Oldbie
Hi guys, I have an HP Z400 workstation with a Xeon W3520 installed. I want to juice it out a bit more, so I found that the Xeon W3690 seems to be the most powerful LGA1366 processor. But I'm not sure the mobo could take it. I mean the socket is correct, but what about power/heat/BIOS? Especially that according to the HP z400 official specs, it was not one of the options:
https://support.hp.com/ca-en/document/c01709672
I don't know if they didn't list it because it wasn't out at the time or because the machine can't handle it. Any insights on whether I should take the chance or even better alternatives? I don't mind buying it anyways as long as it doesn't burn my mobo during testing 😀 As I like this machine a lot thanks to its ability to run a fully native DOS setup with sound card and floppy drives, while it is still able to push Windows 11!
Cheers!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
