First post, by treeman
I am trying to repair this board which gives me nothing. Without a scope I am taking a few guesses at the clock gen and crystals.
I changed the 14mhz crystal since I had one but no luck. Next to the crystal is a chip chrontel ch9007d-n which would no doubt be the clock gen or some clock invertor?
I can't find much info on this chip, does anybody know this part, what it does and also is there any more modern replacement?
Thanx
Reply 1 of 3, by pshipkov
That is rarely the case. Check jumpers configuration first.
Do you get beeps upon power on ?
Also, recently had several boards with some of the legs of the main ICs loose.
Once soldered properly things started working again. Figured i should mention it just in case.
retro bits and bytes
Reply 3 of 3, by treeman
I edited the post, was measuring the wrong pin.. cpu reset pin is ok.
I measured the 14mhz crystal next to the clock gen with a voltmeter in hz mode it showed nothing. Showed a 6mhz for a moment then 0
Just to be sure I measured the 32mhz crystal for the bios and that showed up properly so my voltmeter is ok.
I guess my original assumption for the clock gen chip could have something to it
