First post, by AvocadoLongfall
Hey everyone, I have been attempting to get the L2 cache to work as I have installed it in the correct orientation and know that these chips have been tested to work. I went to turn off the cmos battery for ten minutes, played around with the jumper settings. I am clueless how to remedy this.
The cache in question is 256k L2 sram
Reply 1 of 7, by jakethompson1
Don't you need a Dirty RAM in the 22-pin socket next to the tag RAM? Maybe you can temporarily set up a jumper wire to do an "always dirty" configuration just to get it working?
Reply 2 of 7, by AvocadoLongfall
Ah, what exactly should I search for to obtain whatever you have mentioned?
Reply 3 of 7, by CoffeeOne
AvocadoLongfall wrote on 2023-02-26, 04:48:
Hello,
I never heard of "MAGIC" 64kx8 sram chips. Are you sure these are not fake?
Where did you test those chips?
EDIT:
I found a reference here:
LS486e trouble booting with L2 cache on(2x66)
so I might be wrong.
Seem to be rare though. I don't know.
Reply 4 of 7, by CoffeeOne
CoffeeOne wrote on 2023-02-26, 22:18:
Hello, […]
Hello,
EDIT:
MORE EDIT:
I read that you have a lot of 32kx8 sram chips.
If yes, remove those Magic chips, and put 4 times 32kx8 inside instead in order to check if 128kB is working correctly!
Reply 5 of 7, by AvocadoLongfall
I have received the dip22 chip. Once Installed it next to the tag ram, the cache was detected and shows 128k. Man does the computer feel quite a bit faster and more responsive.
Reply 6 of 7, by CoffeeOne
AvocadoLongfall wrote on 2023-03-02, 02:15:
So you did remove those "Magic" chips? And put back the 32kx8 chips?
Reply 7 of 7, by AvocadoLongfall
Nope. The cache check tool does not even tell me they are fake. It says it detected l1 and l2 cache so it is real cache.
