First post, by ajacocks
I just got a rather interesting low-profile 386SX/20 desktop from Zenith called the Z-LS/20. It’s a slim chassis with only a single 3.5” floppy drive, mounted facing right, rather like a SPARCstation 1, 1+, 2, or 10. When I received it, there was significant corrosion on the mounting tabs for the power supply, which turned out to be from long-remaining electrolyte from some leaked capacitors. I cleaned that up, scrubbed the PCB, and replaced the caps, and miracle-of-miracles, it actually worked.
The machine’s onboard VGA creates a sync signal, but I get nothing onscreen, so that needs to be troubleshot. However, with an accessory video card, I can see that the machine powers up and posts, and wants to have its CMOS options set. There is a BIOS password preventing that, though.
Normally, I’d use one of the DOS-based BIOS hacking tools to get the password, but I can’t set a boot device, and there is no option to skip the password. I also can’t find a reset jumper or set of pads, on the motherboard. It’s also interesting to me that there is a password at all, as the CMOS battery was 100% dead, when I received it. I assume that it must be a manufacturer-supplied default password.
I have already tried all of the passwords that I found on the various known BIOS password lists that I have found.
Any advice would be much appreciated.
Thanks!
- Alex
Reply 1 of 9, by jakethompson1
Can you dump the BIOS chip or find a copy of it online?
Reply 2 of 9, by Horun
Good thought jakethompson1 ! Reminds me: Some one else a year or so ago had a old board and it was set to always ask even if no password was ever set. Ended up a corrupt BIOS iirc..
Reply 3 of 9, by ajacocks
I finally managed to dump the BIOS for this machine. I'm not sure why I didn't get notified of your response @jakethompson.
I uploaded it to archive.org:
https://archive.org/details/zenith-z-ls-20-bios
And, attached it here, as well.
Thanks!
- Alex
Reply 4 of 9, by ajacocks
Here's what the board looks like:
The attachment IMG_0066.jpeg is no longer available
The attachment IMG_0062.jpeg is no longer available
The attachment IMG_0065.jpeg is no longer available
- Alex
Reply 5 of 9, by Predator99
Can you also post a Screenshot of the Password query please?
Do you have a POST card? Which Code does it show when the Password is requested?
Reply 6 of 9, by jakethompson1
Predator99 wrote on 2023-03-01, 15:56:
Hello, Predator99. I was taking a look at this and talking to ajacocks. The "get password" function is F000:5989 and I'm having trouble determining how it validates the password as it doesn't seem to actually validate anything, but just accepts the password if certain unusual scan codes (0xFF or 0xFD) are received. The function that seems to determine whether or not to even prompt for a password (F000:5900) is also hard to follow and seems determined by values pulled from the KBC and keyboard rather than anything in the CMOS RAM.
Reply 7 of 9, by Predator99
Ok thanks for Information! Didnt take a look At the dump so far.
I would not try to crack the Password.
I would patch out the whole query and write back the modified BIOS.
Will need a Programmer of course.
Reply 8 of 9, by jakethompson1
Predator99 wrote on 2023-03-01, 16:33:
Ok thanks for Information! Didnt take a look At the dump so far. […]
The password was bypassed with:
1B833: 75 -> 90
1B834: 04 -> 90 (bypass ROM checksum)
15A17: 50 -> CB
15B16: 50 -> C3 (eliminate password check)
It's still unclear what causes the password prompt to be triggered in the first place, and even more unclear what determines a valid vs. invalid password.
Reply 9 of 9, by Predator99
Excellent work, thanks for Information! Did
you run the BIOS in an Emulator or did you only inspect it with a disassembler?
