First post, by dominusprog
- Oldbie
Hi
So I bought this BTC 1817DW with an OPTi 931 and QDSP chip; it was working in the previous installation. But after I changed the hard drive and installed everything from scratch, no matter what I do, the wavetable doesn't work in DOS.
Any suggestion?
@ECHO OFFSET BLASTER=A220 I5 D1 T4SET SOUND16=C:\OPTI931PROMPT $p$ggoto %config%:WINDOWSC:\OPTI930\SNDINIT /bC:\WINDOWS\WIN.COMgoto end:MSDOSSET CTCM=C:\WINDOWSLH C:\WINDOWS\COMMAND\DOSKEY.COMLH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:ASUSCD01LH C:\OPTI931\SNDINIT /bLH C:\S3\S3VBE20.EXE /INSTALLLH E:\DRIVERS\CTMOUSE\CTMOUSE.EXE /S1PATH %PATH%;C:\NCgoto end:end
[MENU]MenuItem=WINDOWS, Load Microsoft Windows 95 [Default]MenuItem=MSDOS, Start system in MS-DOS compatibility mode.MenuDefault=WINDOWS,05[COMMON]FILESHIGH=30BUFFERSHIGH=30,0STACKSHIGH=9,256DOS=HIGH,UMBREM - By Windows 95 Network for LastDrive - LASTDRIVE=H[WINDOWS]DOS=UMBDEVICEHIGH=C:\WINDOWS\SETVER.EXEDEVICEHIGH=C:\ASUS_CD\ASUSCD.SYS /D:ASUSCD01[MSDOS]DOS=HIGH,UMBDEVICE=C:\WINDOWS\HIMEM.SYSDEVICE=C:\UMBPCI\UMBPCI.SYSDEVICEHIGH=C:\WINDOWS\SETVER.EXEDEVICEHIGH=C:\ASUS_CD\ASUSCD.SYS /D:ASUSCD01
Driver
https://archive.org/details/BTC_1817_OptiSoun … CD_Windows_1998
