BTC 1817DW Driver Issue
First post, by dominusprog
Hi
So I bought this BTC 1817DW with an OPTi 931 and QDSP chip; it was working in the previous installation. But after I changed the hard drive and installed everything from scratch, no matter what I do, the wavetable doesn't work in DOS.
Any suggestion?
@ECHO OFF
SET BLASTER=A220 I5 D1 T4
SET SOUND16=C:\OPTI931
PROMPT $p$g
goto %config%
:WINDOWS
C:\OPTI930\SNDINIT /b
C:\WINDOWS\WIN.COM
goto end
:MSDOS
SET CTCM=C:\WINDOWS
LH C:\WINDOWS\COMMAND\DOSKEY.COM
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:ASUSCD01
LH C:\OPTI931\SNDINIT /b
LH C:\S3\S3VBE20.EXE /INSTALL
LH E:\DRIVERS\CTMOUSE\CTMOUSE.EXE /S1
PATH %PATH%;C:\NC
goto end
:end
[MENU]
MenuItem=WINDOWS, Load Microsoft Windows 95 [Default]
MenuItem=MSDOS, Start system in MS-DOS compatibility mode.
MenuDefault=WINDOWS,05
[COMMON]
FILESHIGH=30
BUFFERSHIGH=30,0
STACKSHIGH=9,256
DOS=HIGH,UMB
REM - By Windows 95 Network for LastDrive - LASTDRIVE=H
[WINDOWS]
DOS=UMB
DEVICEHIGH=C:\WINDOWS\SETVER.EXE
DEVICEHIGH=C:\ASUS_CD\ASUSCD.SYS /D:ASUSCD01
[MSDOS]
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\UMBPCI\UMBPCI.SYS
Driver
https://archive.org/details/BTC_1817_OptiSoun … CD_Windows_1998
The attachment SAM_2326.JPG is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 1 of 3, by stanwebber
this may not be your problem, but why do you have
in your config? i have a 82c930 card and i think the dos drivers are different (nt drivers are combined if i remember).
Reply 2 of 3, by dominusprog
stanwebber wrote on 2023-03-04, 14:43:
Ah yes, I copied it from the backup I have. The thing is, there's no separate driver for DOS like the 930, but I have to install the Win3.1 driver from Windows.
Reply 3 of 3, by dominusprog
Problem solved! There's an option in SOUND16.CFG named FDAC_SRC with four possible options: OPL3/ASIO/MIX/SHARE. The default option is OPL3, so changing this to SHARE should fix the problem.
Is there anyone who knows what the MIX option does? Can FM-Synth and Midi be used at the same time?
