First post, by cyclone3d
- l33t++
I purchased an Epox EP-D3Va and it arrived a few days ago.
Also found a second poorly listed Lin-Lin adapter around the same time and bought it.
Finally got a chance to test the board today and it seems to be working fine with Dual PIII-1.4Ghz Tualatin CPUs other than the bus speed, CPU speed and RAM speed being detected incorrectly.
Also try a different power supply as 12v seems a bit high. The first PSU I tried didn't have as many amps on the 5v line and it was running at 4.65v... uggghhh.
Will be trying a much newer PSU that should have much better voltage regulation.
Brand new coolers but I really don't like the vibration / speed of the fans. I'll be trying out the Stock Intel ones but not sure they will clear the capacitors, even with the Lin-Lin adapters.
Initial pics of testing:
