Matrox G200 for DOS?
First post, by appiah4
Does anyone use a Matrox G200 for DOS and can they tell me how good that works?
I checked Gona's DOS compatibility matrix but things look pretty bad. However, according to the same matrix things look equally bad for cards like Mystique and G450 and I did not encounter half the problems he says there is. I mean, screen tearing in Duke3D and Quake are news to me. So, I thought I'd ask about any first hand experiences. I'm mostly interested in how well it runs games from 1993 and onward.
Just asking because I'm considering building a mATX DOS/Win98SE dual boot reverse-sleeper PC..
Reply 1 of 11, by The Serpent Rider
If you need performance info, I've got you covered with my recent G200 MMS test:
The attachment MatroxBench.png is no longer available
That's from my slowly crawling update to "Electric boogalo" benchmark topic. With S3 Trio64V+ and Tseng ET6000 added for comparison. In short, G200-G550 cards behave almost identically.
Reply 2 of 11, by appiah4
The Serpent Rider wrote on 2020-09-12, 18:05:
Thanks, very helpful. Did you notice any irregularities/artifacts in games like Doom, Duke3D, Quake etc?
Reply 3 of 11, by The Serpent Rider
Nothing unusual in common stuff.
Reply 4 of 11, by dr.zeissler
I just checked a G200 AGP in Dos. It seems to me that the G200 is a bit slow in Dos (Duke3D, Swarrior) in 800x600 and also in 640x480.
I noticed screentearing on TFT too...I don't think that MGA Mystique PCI has this too. I have to recheck this..
Reply 5 of 11, by iraito
I use a G200 on my MMX build and i did not encounter any of the issues noted on the matrix BUT that only after using 136 in 1 to slowdown my CPU to a 386\486 etc. personally after slowing down matrox cards work pretty damn smooth.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 6 of 11, by The Serpent Rider
dr.zeissler wrote on 2023-03-22, 20:34:
Common issue with VESA on Build engine and "modern" system specs, need to disable LFB or apply MSKVBEF patch.
Reply 7 of 11, by dr.zeissler
How can I bench my system in order to proof it?
Reply 8 of 11, by The Serpent Rider
All necessary tools were mentioned here and there many times, including my benchmark thread.
Reply 9 of 11, by dr.zeissler
thx I will have a look...
Reply 11 of 11, by luk1999
I guess that he meant mtrrlfbe.
P4 3.4E, P4C800-E Deluxe, 1 GB RAM, X800PRO 128 MB AGP, SB Audigy, XP SP2
XP2000+, KT2 Combo, 512 MB RAM, GF4Ti4200 64 MB AGP, FM801, Me
C500, Garry, 128 MB RAM, Voodoo 2 12 MB, TNT2 PRO 32 MB, ALS100 Plus+, 98SE
