Alaris Leopard Rev C 486SLC2 (MR-BIOS???)
Reply 21 of 45, by Anonymous Coward
Finally, this is found!
Too bad it'll be several months before I'm able to test it.
Is there a small performance gain over AMIBIOS?
Reply 22 of 45, by sonicx
Unfortunately, there is no performance gain. Only support for large disks has been added.
Reply 24 of 45, by ltning
I finally got mine installed and running in a case, and while it's not exactly a speed demon, it's quite nice.
About the aforementioned VLB VGA compatibility though: I found a card that doesn't work! I have a Tseng ET4000/W32p VLB card that works fine in a number of machines - but not in this one. That is to say, it works as long as the external cache is off, but any attempt to turn external cache on will prevent it from getting past the POST+option ROM stages. All manner of wait states and timing settings have been explored.
I'm suspecting it has to do with the 16-bit bus, which the Tseng (well, this implementation of it, anyway) doesn't like.
I also have a Genoa Phantom64 S3-based card which worked for a while, but then stopped - soon after I started my attempts at overclocking to 40MHz bus speed. I haven't tested in any other machines yet, so I have no idea if the damage is permanent or system-specific..
Right now it's got a different S3 868 card, miroVIDEO 20SD. Seems to work.
Biggest problem right now is the inability to reboot the system using c-a-d or even the reset button! The former hangs the machine, the latter causes no video signal (and no booting).
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 25 of 45, by Predator99
mat919 wrote on 2023-01-30, 17:18:
Anonymous Coward wrote on 2023-01-22, 09:49:
No, this BIOS image is surprisingly still missing.
I have hoarded over some time an extensive collection of MR BIOSes. I just purchased the board with AMI and looking forward to an upgrade, but since I paid a lot of money for it I am afraid to ruin it on the very next day. Is there anything in particular, that would allow me to pinpoint correct version of MR? A string inside the rom?
If you have an advanced knowledge and/or resources to play with and a know-how , to protect yourself from bricking the board I could upload a rom candidate that look promising in my opinion. LMK.
Can you please also upload your collection here if there are some additions?
How about a MR-BIOS ROM file repository?
Thank you:-)
Reply 26 of 45, by iPonRMA
ltning wrote on 2023-03-27, 21:06:
I finally got mine installed and running in a case, and while it's not exactly a speed demon, it's quite nice. […]
I also tried that board with VLB cards: Tseng ET4000s didnt work except one in one VLB, some S3s works some didnt (mostly diamonds, except the Trio64), and the fastest was also an S3 one, a Trio64 STB card:
https://www.youtube.com/watch?v=T0FWZevKlUY
Reply 27 of 45, by Anonymous Coward
I'm pretty sure I tested a Hercules Dynamite Power (et400ow32p) in my Alaris board, and it worked. I was curious and I think I tested my entire pile of VLB cards, and they all worked. Though admittedly I did not test windows drivers.
Reply 28 of 45, by kixs
I got one of these that won't boot. PC speaker gives error codes with High and Low beeps. It has MR. Bios chip.
Error code is:
LH-HHLLH Real-time clock failure
Does anyone have any idea what is going on and how to proceed?
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 33 of 45, by Anonymous Coward
I believe we have a dump from a Rev A board.
Perhaps the BIOS on the Rev C board has improvements.
Reply 34 of 45, by Gennadios
Hey folks, sorry to bother but I found what looks like a rev C board with battery damage. Does anyone onow the values for D5 and R51?
The attachment PXL_20240930_082952511.jpg is no longer available
Mine has the AMI bios so Im no help in tracking down the missing image.
Reply 35 of 45, by RayeR
A got this MB from scrap today 😀
It's rev. C with AMI BIOS, SLC2-50, w/o FPU.
It has also leaked accu but not much excessive. I just desoldered it off and seems no damage to PCB was done yet so it could work.
R51 should be 100ohm according the SMD code. As a D5 you can probably use any similar generic diode but it doesn't seem to be damaged, just oxidized. Desolder it, clean the PCB, solder it back...
Reply 36 of 45, by RayeR
The MB is running. R51 is 100 ohm.
Reply 37 of 45, by Gennadios
RayeR wrote on 2024-10-07, 19:17:
A got this MB from scrap today :) It's rev. C with AMI BIOS, SLC2-50, w/o FPU. It has also leaked accu but not much excessive. I […]
Much appreciated, this is my first experience with Varta damage, wish me luck.
Reply 38 of 45, by RayeR
I tested 2 VLB VGA cards in this MB
S3 765VL - doesn't work (garbage on boot screen)
Cirrus Logic CL-GD5429-86QC - works, benefit in Doom compared to ISA VGA is 11,80 FPS vs 9,38 FPS (poor, choked by slow 16-bit bus)
Reply 39 of 45, by Datbluehusky
Anonymous Coward wrote on 2023-11-23, 15:05:
was yours a mr bios? please let us know and dump it, theres currently no rev c mrbios uploaded and would love to try it. I have same board but mines amibios
