Reply 20 of 44, by Nexxen
- l33t
Trashbytes wrote on 2023-07-08, 15:26:Nexxen wrote on 2023-07-08, 15:23:https://overclockers.ru/lab/show/77627_2/retr … -pro-socket-8#4 […]
Trashbytes wrote on 2023-07-08, 14:58:The Pentium Pro OD was the same setup as used in the Pentium II Xeon unlike the Pentium II retail CPUs the PPOD had the cache running at full CPU speed, the 333 PPOD should in theory run faster than a PII 333 due to the faster cache. The only catch I guess is the lack of a 100Mhz bus and no AGP, but I do love the Pentium Pro OverDrive CPUs.
Looks like it if you check results.
It's a very interesting article and the author has more (click on his username).He even goes as far as putting S8 cpus on S8-to-Slot1 adapters.
https://overclockers.ru/lab/show/102888/retro … i-final-istoriiI want one of them Socket 8 to Slot 1 cards.
I think they come $50 a piece.
IIRC the seller is on Vogons and posted about it.
Edit: https://www.cpushack.com/2020/09/09/finding-t … f-the-socket-8/
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
