Pentium Pro
Reply 20 of 44, by Nexxen
Trashbytes wrote on 2023-07-08, 15:26:
Nexxen wrote on 2023-07-08, 15:23:
https://overclockers.ru/lab/show/77627_2/retr … -pro-socket-8#4 […]
Trashbytes wrote on 2023-07-08, 14:58:
The Pentium Pro OD was the same setup as used in the Pentium II Xeon unlike the Pentium II retail CPUs the PPOD had the cache running at full CPU speed, the 333 PPOD should in theory run faster than a PII 333 due to the faster cache. The only catch I guess is the lack of a 100Mhz bus and no AGP, but I do love the Pentium Pro OverDrive CPUs.
Looks like it if you check results.
It's a very interesting article and the author has more (click on his username).
He even goes as far as putting S8 cpus on S8-to-Slot1 adapters.
https://overclockers.ru/lab/show/102888/retro … i-final-istorii
I want one of them Socket 8 to Slot 1 cards.
I think they come $50 a piece.
IIRC the seller is on Vogons and posted about it.
Edit: https://www.cpushack.com/2020/09/09/finding-t … f-the-socket-8/
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 21 of 44, by Trashbytes
Nexxen wrote on 2023-07-08, 15:28:
I think they come $50 a piece. IIRC the seller is on Vogons and posted about it. […]
Holy hell some of the benchmarks on a late BX board is quite something.
Reply 22 of 44, by luckybob
man, 2 hours old, and i'm very late to this thread.
That said, I really want to put some water on the fire of popularity of these chips. I want to go back in time when these were cheap...
What kind of software would be the optimal showcase for this kind of CPU, something floating point heavy maybe?
Short answer? NT4 and CAD. but honestly, a late dos gaming rig is about par for the coarse.
Reply 23 of 44, by OSkar000
Pentium Pro has always been really special to me.
I have one that runs Windows NT 3.51 that will get some fun upgrades soon 😀
Reply 24 of 44, by Nexxen
What is this? Pentium Pro agit-prop thread???
Reply 25 of 44, by Scali
doublebuffer wrote on 2023-07-07, 16:41:
Anyone here have any experience with Pentium Pros? There seems to be very little info on the internet, most saying they are useless for anything 16-bit, is that really true or an urban legend?
'Useless' is a bit of a broad statement.
What happens is that the register renaming scheme introduced on the Pentium Pro has issues with 'partial registers' (the 8-bit and 16-bit registers, like al, ah, ax etc). Its internal registers are all 32-bit, so any partial register gets renamed to a 32-bit internal register.
When you then access a larger register again (eg eax), it has to recombine the partial registers (al, ah, ax and the unnamed top 16-bits of eax) again.
This causes a stall of the pipeline.
The issue exists both in 32-bit and 16-bit code, but in 16-bit code basically everything is a partial register.
In the Pentium II they introduced a workaround for this:
They implemented a flag to indicate the special case that the entire register was zero before a partial register was renamed. This means that it can skip the recombination step, so performance is much better in that case.
Still that didn't help legacy code that much. It mainly worked when code was specifically compiled to zero registers before use.
Originally they were probably aimed towards workstations and servers, but could they be paired with some nice video card to get a decent era-appropriate (1995ish) gaming experience?
Sure.
I have a Pentium Pro 200 machine, which is a Compaq Deskpro XL6200.
It's basically just a high-end desktop system, with regular PCI slots (AGP didn't exist yet), SCSI and IDE controllers and such.
So you can put a decent PCI 3D accelerator in there.
Mind you, in those days, you'd run Windows 98 for gaming, which is partly a 16-bit OS, so performance is not optimal on a Pentium Pro.
My system only has 64 MB, so it won't run Windows 2000 or XP very well. But Windows 98SE gets the job done reasonably well.
Reply 26 of 44, by Trashbytes
I have a Pentium Pro 1Mb 200 system that I paired with a PCI MX400, 8Mb Voodoo2 and a AWE64 Gold, its a rock solid late DOS early Win95 system that can throw some early 3D gaming around.
I had the Floppy version of 95 sitting around doing nothing, seemed like the perfect fit for a Pentium Pro box !
Been thinking of throwing a Overdrive in it but at that point I may as well just build a Slot 1 98 Rig, I wonder if its possible to overclock the 200 to 233.
Reply 27 of 44, by The Serpent Rider
Nexxen wrote on 2023-07-08, 21:32:
Conspiracy to hike up PPro prices even more!
Reply 28 of 44, by Jo22
Trashbytes wrote on 2023-07-15, 12:34:
Win95.. Ah, the memories! I've had a few Windows 95 CDs..
One served me well for playing Frisbee with my little sister, another one turned into a shiny wall clock. 😂
Reply 30 of 44, by Trashbytes
Jo22 wrote on 2023-07-15, 12:38:
I know its rather antiquated 🤣 but 98Se is rather overused and I already have a nice 98 rig ...seemed such a waste to not do a Floppy install ..."27 Discs later"
That reminds me I should sanitise the floppy drive in that rig ...dont want the Win95 STD to infect other more important Discs.
Reply 31 of 44, by doublebuffer
Youtube has videos where they trash heaps of PPros... so painful to watch. They get maybe 50 cent worth of gold from each, destroying a 100$ cpu in the process.
Reply 32 of 44, by NostalgicAslinger
doublebuffer wrote on 2023-07-15, 13:05:
This is the modern consumer society.
Reply 33 of 44, by Nexxen
"Saving Pentium Pro Society"
Could work?
Reply 34 of 44, by The Serpent Rider
"Hoarding Pentium Pro Society"
Reply 35 of 44, by Nexxen
The Serpent Rider wrote on 2023-07-15, 16:12:
Keep it down... "They" must not understand the plan. 😀
This is a very old topic, unfortunately gold is gold, history isn't.
We can write haikus in remembrance.
Reply 36 of 44, by maxtherabbit
I just recently did a blacktop build, overclocked it to 233MHz and stuck voodoo2 sli in there. Really great performance under windows 98SE
Reply 37 of 44, by luckybob
It really chapped my ass to pay what I did for the OD processors I did get last week. I honestly did not expect to win them, but I bid and won so I girded my loins and paid. I mean, they are NIB, and I have a burning desire to open the boxes and use them.
maxtherabbit wrote on 2023-07-15, 18:11:
EHH... IMHO the Voodoo 1 is more appropriate for a p-pro in terms of matching cpu and gpu power. I'd personally pair a V2-SLI setup with a Pentium 3, but if you're happy, it doesn't really matter what I think.
Reply 38 of 44, by luckybob
The Serpent Rider wrote on 2023-07-07, 16:44:
Graphics card for Pentium Pro build Dual Pentium Pro Build Thread My Painful ASUS P/I-P65UP5 C-P6ND Dual Pentium Pro - Vobis Hig […]
My Painful ASUS P/I-P65UP5 C-P6ND Dual Pentium Pro - Vobis Highscreen Colani Tower Build
Article about extreme overclocking and modding: https://overclockers.ru/lab/show/77627/retrok … um-pro-socket-8
You forgot this big beast of a setup:
Bitchin' dual p-pro setup
Reply 39 of 44, by maxtherabbit
luckybob wrote on 2023-07-15, 18:32:
Voodoo 1 will not perform anywhere near this level
The attachment 20230715_151310.jpg is no longer available
