Confused UngaBunga wrote on 2023-07-12, 17:27:I do have two Socket A-K7Mobile, but none beats the 700MHz coppermine. Are geodes hard to get/expensive? Do they run on normal m […]
I do have two Socket A-K7Mobile, but none beats the 700MHz coppermine. Are geodes hard to get/expensive? Do they run on normal motherboards?
Quiet impressive the geforce2 mx!
Sound doesn't matter much energy wise?
Regarding the memory do you mean those modules with only one side populated?
SSD good call!
PSU seems too much investment though.
What about CRT vs LED?
Should I consider a laptop?
Thanks
This motherboard that i listed before, has support for it, geode cpus not easy to pick up, still possible to find. One sided memory should use less power. Laptop is the easy way. Use mobile or low power cpu for DesktopPC if you can and build from that, i just like AMD builds more.
Faster PC would be K8 S754 with Mobile Sempron or Turion64 cpu (22 to 24w ones), also only single channel so 1xmemory stick ok (single sided). If you want to stay with socket370 and cpu speed does not matter that mutch, then Celeron 533A (coppermine) has 14w usage.
I add three of my AMD Mobile builds here, that i have:
RetroPC-K6Mobile
AMD Mobile K6 266MHz (K6/266ADZ) (Max 9.8W)
Socket7 + Coolermaster Fan 60x60@5V
Aopen AX59 PRO Rev 1.04 (Latest bios 2.36)
1x256MB PC133 CL3 SDRAM-Double Sided (Infineon)
SAMSUNG Spinpoint MP0402H 40GB 5400RPM 8MB 2.5" IDE
Matrox Millennium G200A 8MB AGP (Max 4W)
Diamond Monster 3D 4MB PCI (3Dfx Voodoo)
Creative Labs Sound Blaster AWE64 ISA (CT4520)
Nec 1.44MB (FD1231H)
NEC DVDRW ND-3540A
Retro ATX case 300 PSU
HTPC-K7Mobile
AMD Geode NX 1750+/Mobile Athlon XP 1600+ 1.4GHz (Max 25w)
Arctic Cooling Copper Silent 3 (Copper Lite)
AsRock K7S41GX socket A Rev v1.04 (Halt@Idle enabled bios)
Hynix 1x1GB DDR PC3200 CL3
Seagate Momentus 5400.3 ST9160821A 160GB 5400RPM 8MB ATA100 2.5"
Club 3D AMD/ATi HD3450 512MB DDR2
Integrated 5.1CH C-Media CMI9739A
Hitachi/LG Slim GSA-T40N 8x DVD±RW DL
300W Fortron FSP300-50GMN 80+
Coolermaster N200 MATX
HTPC-K8Mobile
AMD Turion 64 Mobile 1800MHz/512Kb (Max 24W)
K8 CoolerMaster Hiper MC (ECC-00126-01)
CoolerMaster Fan 70x70@5v (+WEN93626)
Asrock K8NF4G-VSTA (Socket 754)
Apacer 1x1GB DDR PC3200 CL3
Corsair Force LS SSD 60GB (CSSD-F60GBLSB)
MSI GeForce GT 720 1GB DDR3 Fanless Edition (Max 19W)
7.1 CH ALC883 Audio (DTS-HD-MA, Dolby TrueHD)
Samsung Slim Blu-ray Writer SN-506BB (+Lindy 40513,33608)
Akasa 3,5" Memory Card Reader + USB 2.0 (AK-ICR-03USB)
350W Fortron FSP350-60EGN 90+ 80 PLUS® Gold (+24pin->20pin)
White MATX (small case)
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
