Frank Grudge wrote on 2023-10-15, 02:36:
majestyk wrote on 2023-10-13, 08:02:Are you sure the Necroware VRM will provide the 3.3V I/O voltage? I don´t think so:
https://github.com/necroware/s7-vrm […]
Frank Grudge wrote on 2023-10-13, 06:45:
It might be best to purchase a MMX processor and go for a Necroware VRM module. And do away with the single 3.3v switching regulator on the motherboard.
The onboard regulator of the mainboard is still necessary for dual voltage operation. It provides 3.3V I/O while the VRM module proviodes the core voltage.
I see your point i havnt looked at the pinout for the VRM module thanks.
You can try to use single voltage CPUs on your motherboard with Necroware VRM (with broken onboard regulator) - if there aren't more broken elements.
I can confirm that on Shuttle HOT-541 with onboard regulator disabled, Pentium-S 120 works just fine on 3.2V setting.
However, you can try to repair it -inductor can be self made - we can see from photo in the other thread, that original one has 21 loops, and diameters of the ferrite cores are standardized - you can measure ring on motherboard and choose the "slightly smaller one" 😀 There is also thing called permeability (μ'), but usually same color of ferrite toroid with the same diameter means same permeability (but not always). https://coil32.net/online-calculators/ferrite … calculator.html
Double Shottky diode can be borrowed from old ATX PSU. And third element (probably mosfet) can be guessed if you try to draw part of schematics containing TL494, Shottky, mosfet and inductor (and small elements close to them)... Especially the way how those three are connected to TL494.
Maybe I'm too optimistic, but why not to try 😀
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
