First post, by Frank Grudge
Some time ago I purchased this P54TA Socket 7 motherboard for repair.
The motherboard also came with a 1st gen Pentium 166Mhz processor.
See the photos below, the board is missing voltage regulator circuitry I’ve identified componests removed as mosfet, diode and inductor. Ideally id like to find out suitable replacements or even board schematics.
The other option is to install a VRM module, I have checked out the board by Necroware but its really designed for MMX or K6 cpus with lower core voltages
Keen to hear your tips on how to get this board going. Thanks
Reply 1 of 15, by giantclam
Fixed voltage, TL494 PWM controlled regulator circuit .... I voltage only
Reply 2 of 15, by texspex
This thread seems to have the same motherboard: Help identifying P54TA Socket 7 motherboard
I can make out from the pic F10P040 for the big schottky barrier diode, but can't make out the text from the smaller 3 legged chip.
Reply 3 of 15, by zyga64
Easiest way would be to ask user SVD then 😉
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 4 of 15, by Frank Grudge
giantclam wrote on 2023-10-10, 11:34:
Correct, there is also a TL431 vref on the board, i have looked online for socket 7 boards with similiar topology with no luck
Reply 6 of 15, by Frank Grudge
It might be best to purchase a MMX processor and go for a Necroware VRM module. And do away with the single 3.3v switching regulator on the motherboard.
Reply 7 of 15, by majestyk
Frank Grudge wrote on 2023-10-13, 06:45:
Are you sure the Necroware VRM will provide the 3.3V I/O voltage? I don´t think so:
https://github.com/necroware/s7-vrm
The onboard regulator of the mainboard is still necessary for dual voltage operation. It provides 3.3V I/O while the VRM module proviodes the core voltage.
Reply 8 of 15, by zyga64
Necroware VRM can provide 3.2 which should be sufficient (for single voltage CPU).
Reply 9 of 15, by majestyk
Single voltage MMX?
Reply 10 of 15, by zyga64
You are right. I didn't read previous reply carefully 🤦
Reply 11 of 15, by Frank Grudge
majestyk wrote on 2023-10-13, 08:02:
Are you sure the Necroware VRM will provide the 3.3V I/O voltage? I don´t think so: https://github.com/necroware/s7-vrm […]
I see your point i havnt looked at the pinout for the VRM module thanks.
Reply 12 of 15, by zyga64
Frank Grudge wrote on 2023-10-15, 02:36:
You can try to use single voltage CPUs on your motherboard with Necroware VRM (with broken onboard regulator) - if there aren't more broken elements.
I can confirm that on Shuttle HOT-541 with onboard regulator disabled, Pentium-S 120 works just fine on 3.2V setting.
However, you can try to repair it -inductor can be self made - we can see from photo in the other thread, that original one has 21 loops, and diameters of the ferrite cores are standardized - you can measure ring on motherboard and choose the "slightly smaller one" 😀 There is also thing called permeability (μ'), but usually same color of ferrite toroid with the same diameter means same permeability (but not always). https://coil32.net/online-calculators/ferrite … calculator.html
Double Shottky diode can be borrowed from old ATX PSU. And third element (probably mosfet) can be guessed if you try to draw part of schematics containing TL494, Shottky, mosfet and inductor (and small elements close to them)... Especially the way how those three are connected to TL494.
Maybe I'm too optimistic, but why not to try 😀
Reply 13 of 15, by Frank Grudge
zyga64 wrote on 2023-10-16, 08:14:
You can try to use single voltage CPUs on your motherboard with Necroware VRM (with broken onboard regulator) - if there aren't […]
Many thanks for your response this gives me some direction i will try substitute parts and trace out the TL494 topology to find a suitable mosfet 😀 cheers
Reply 14 of 15, by zyga64
And don't forget to replenish the missing RTC chip (Dallas DS12887) or a modern replacement such as https://github.com/necroware/nwX287
