First post, by douglar
I found a big box of CPU's the other day while looking through e-waste. There were about 50 socket 3 through socket A CPUs jumbled loose at the bottom.
Re: I recently found this hardware, AKA the Dumpster find thread.
Project pin straightening has been going pretty well for several days now. Something to do during endless conference calls.
The Socket 3 & 4 CPU's were pretty easy, but the Socket 5, 7, 370, & A are a little harder. I cut a thin plastic gift card like this and it is helped a lot. As long as the pins are not bent more than 20 degrees, I can slide it through and bend them back.
The attachment Pin Straightening Palooz.jpg is no longer available
Everything is finished except for one Socket 7 MMX that has lots if elbowed pins and a socket A Athlon XP with the brown OPGA with a pin that was bent completely flat. When I tried to lift it with tiny pliers, it fell off.
The attachment Pin Straightening Palooza.jpg is no longer available
Looking at the data sheet, it looks like VSS.
The attachment Pin Straightening Palooza 2.jpg is no longer available
Do I need to try to reattach it or can I skip on one of the many VSS pins?
