First post, by douglar
I found a big box of CPU's the other day while looking through e-waste. There were about 50 socket 3 through socket A CPUs jumbled loose at the bottom.
Re: I recently found this hardware, AKA the Dumpster find thread.
Project pin straightening has been going pretty well for several days now. Something to do during endless conference calls.
The Socket 3 & 4 CPU's were pretty easy, but the Socket 5, 7, 370, & A are a little harder. I cut a thin plastic gift card like this and it is helped a lot. As long as the pins are not bent more than 20 degrees, I can slide it through and bend them back.
34.32 KiB
Everything is finished except for one Socket 7 MMX that has lots if elbowed pins and a socket A Athlon XP with the brown OPGA with a pin that was bent completely flat. When I tried to lift it with tiny pliers, it fell off.
89.12 KiB
Looking at the data sheet, it looks like VSS.
61.24 KiB
Do I need to try to reattach it or can I skip on one of the many VSS pins?
Reply 1 of 2, by gerwin
douglar wrote on 2023-10-13, 00:17:
Should work fine with the remaining VSS pins.
I have a Socket 370 Pentium III with a missing VTT pin. It works as if nothing happened.
Reply 2 of 2, by Sphere478
Looks reparable with flux and a hot air station?
But will probably work without it
Sphere's PCB projects.
