First post, by Kouwes
I have this FIC 486-GIO-VT board without cmos battery so I figured I‘ll just grab an external 3 x AAA battery holder…
Turns out the board has a jumper for internal/external battery. Too bad you can‘t set the jumper to 1-2 because there‘s a cap blocking it.
Any ideas how to bridge pin 1-2 without crazy bending and soldering?
It‘s J3, jumper is set to Internal Battery 2-3.
Looks like the original coin cell holder was removed at some point, there‘s some solder tin left in the holes.
I wonder why. But I do have a CR2032 holder from some scrap board which I could use.
    1.79 MiB
Reply 3 of 9, by analog_programmer
Hmmm, isn't J1 4-pin header for 4.5V external battery connection?
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 4 of 9, by pan069
analog_programmer wrote on 2023-10-29, 19:18:
Yes, but to enable external battery he need to enable it on the board with JP3, the 3 pin jumper block next to it.
Reply 5 of 9, by analog_programmer
pan069 wrote on 2023-10-29, 19:47:
JP3 or J3? I can't see JP3. And what is the problem if (probably) J3 has to be removed?
Reply 6 of 9, by Kouwes
It‘s J3, a 3 pin header currently set to pin 2-3. You can clearly that there is no room for a jumper between the tantalum cap and pin 1. Bending the cap is no option, it won‘t move at all because the legs are too short.
I‘ll try stripping a jumper .
Reply 7 of 9, by analog_programmer
Kouwes wrote on 2023-10-29, 21:07:
I didn't saw the third pin on J3, sorry. Just bend slightly the two tantalum caps to the side so the jumper will fit or bend the pins 1 and 2 of J3.
But I think there's a chance that position 1-2 on J3 is just a "holder" for the jumper and pins 2 and 3 on J3 are in parallel with pins 2 an 3 on the J1. Check the schematic with multimeter in continuation mode.
Reply 8 of 9, by majestyk
This would be true for larger cylindric electrolytics. Tantalums become narrower at the bottom end, so they can be bent easily. I have done that hundreds of times.
Reply 9 of 9, by Kouwes
Yes you are right. I was too cautious I guess because that wouldn’t be the first cap I break off a board. The jumper now sits on 1-2 so all good!
Thanks for your input.
Now I can finish this build: 486DX2-66, 16MB FPM, Tseng ET4000 and an AWE32.
I might go and look for a nice VLB card though.
