First post, by TeaRex
Hello,
I have two joysticks attached to my Linux PC (64-bit openSUSE 10.3), one digital on USB as /dev/input/js0 and one analog on an old-style game port as /dev/input/js1.
Is there a way to get DOSBox (unmodified current CVS) and/or SDL (SDL 1.2.12-26 from the distro) to "see" only one or the other of these, or at least to select which one should be "seen" as the first joystick? As you all know, most DOS games support only one stick, and I'd like to be able to select the one that works best for each game. Do I do this with the keymapper? Or is there some other way? Thank you for any help!
tearex
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
I have no idea. Maybe there is some SDL-environment variable to select a certain joystick?
_________________
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
There is something in the SDL code that allows a user to choose a specific joystick, but it appears to be in a Linux specific part of the SDL:
        /* First see if the user specified a joystick to use */
if ( SDL_getenv("SDL_JOYSTICK_DEVICE") != NULL ) {
SDL_strlcpy(path, SDL_getenv("SDL_JOYSTICK_DEVICE"), sizeof(path));
if ( stat(path, &sb) == 0 ) {
fd = open(path, O_RDONLY, 0);
_________________
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
4axis_2 (supports one joystick, second joystick used)
Reply 4 of 5, by TeaRex
Erm.. I guess being able to read is an advantage. Point taken. 🙁
tearex
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
Well it's only for the 4axis thing, if you want to swap the 2axis joysticks
(for whatever reason) you have to remap everything using the mapper.
