First post, by TeaRex
Hello,
I have two joysticks attached to my Linux PC (64-bit openSUSE 10.3), one digital on USB as /dev/input/js0 and one analog on an old-style game port as /dev/input/js1.
Is there a way to get DOSBox (unmodified current CVS) and/or SDL (SDL 1.2.12-26 from the distro) to "see" only one or the other of these, or at least to select which one should be "seen" as the first joystick? As you all know, most DOS games support only one stick, and I'd like to be able to select the one that works best for each game. Do I do this with the keymapper? Or is there some other way? Thank you for any help!
tearex
