First post, by Rikintosh
I have this computer, the image produced by the video card has this strange horizontal effect (out of sync?), the attached image I created in photoshop to accurately illustrate the problem. I can also notice a "morié?" ghost in the image.
Facts:
- I'm using an LCD LED monitor in perfect condition, the problem is not with it.
- I already changed the VGA cable
- The graphics adapter is a Mach 64CT onboard from an Intel advanced/(AS?)
- This board is using a low quality ATX power supply connected to an AT adapter (maybe it's a problem with the power supply?)
    286.67 KiB
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 1 of 9, by dominusprog
Look for broken/damaged caps around the chip and the d-sub connector.
Reply 2 of 9, by rasz_pl
I bet image is perfect on CRT because those used analog circuity for syncing. LCD monitors scaler will analyze one line of video to determine horizontal timing and will stick to it no matter what. Video adapter might fluctuate horizontal timings slightly, it would be invisible on CRT.
Reply 3 of 9, by rasz_pl
And another one with same symptoms Horizontal distortion/shimmering on Voodoo Banshee
what model of lcd? can you check with another one?
Reply 7 of 9, by rasz_pl
please list your lcd model number. This for all intends and purposes looks like LCD is somehow interlacing non interlaces source?
Reply 8 of 9, by kingcake
rasz_pl wrote on 2024-02-02, 09:10:
Horizontal banding/artifacting is classic pixel clock phase issues with analog vga input to LCD monitors. Auto adjustment often fails to correctly recover the pixel clock.
http://techmind.org/lcd/phasexplan.html
Reply 9 of 9, by guyjin37
Hey all, thanks for talking about this. I made a post about the same exact issue last night and your comments here really helped me. Cross-linking for reference:
Re: Horizontal distortion/shimmering on Voodoo Banshee
Thanks again! (Auto-adjust was the ticket to lock in the phase and control per task/application.)
