First post, by twiz11
Hey I wanted to add an additional hard drive but I only had the small laptop ones
So I screwed the drive into the CD rom tray since I didn't have any space below. Surprisingly it works well I can't move it given it only has two screws in it
Lost my bay converter years ago since holes were stripped on it
RETIRED
This user is no longer active on VOGONS.
Reply 2 of 4, by dominusprog
This is a mechanical hard drive, it's better to fully secure it using a 5.25 to 2.5" bracket.
https://www.amazon.com/ORICO-Aluminum-Interna … ps%2C762&sr=8-5
Reply 3 of 4, by twiz11
dominusprog wrote on 2024-02-19, 15:48:
yea i removed it and cloned the contents onto a bigger hard drive and replaced the bay with a proper adapter. ill keep it for now for my laptop when that hdd goes
RETIRED
Reply 4 of 4, by twiz11
gerry wrote on 2024-02-19, 15:24:
its a good enough approach and seems stable enough as you say 😀
as other example, with SSDs i have seen them taped to the inside of the case before; they're less fragile/sensitive than HDDs.
ive been hesitant to get SSDs got plenty of scraped hdds from old builds
RETIRED
