First post, by twiz11
Hey I wanted to add an additional hard drive but I only had the small laptop ones
So I screwed the drive into the CD rom tray since I didn't have any space below. Surprisingly it works well I can't move it given it only has two screws in it
Lost my bay converter years ago since holes were stripped on it
Reply 1 of 4, by gerry
its a good enough approach and seems stable enough as you say 😀
as other example, with SSDs i have seen them taped to the inside of the case before; they're less fragile/sensitive than HDDs.
Reply 2 of 4, by dominusprog
This is a mechanical hard drive, it's better to fully secure it using a 5.25 to 2.5" bracket.
https://www.amazon.com/ORICO-Aluminum-Interna … ps%2C762&sr=8-5
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 4, by twiz11
dominusprog wrote on 2024-02-19, 15:48:
yea i removed it and cloned the contents onto a bigger hard drive and replaced the bay with a proper adapter. ill keep it for now for my laptop when that hdd goes
Reply 4 of 4, by twiz11
gerry wrote on 2024-02-19, 15:24:
ive been hesitant to get SSDs got plenty of scraped hdds from old builds
