First post, by BawlsTowers
I'm looking for an awesome X-FI sound card to connect to the Audigy 2 Breakout Box, SB0250. It seems like X-FI Titanium SB0880 will not connect as the SB0250 needs the standard 40pin IDE connect and the SB0880 doesn't have it. However, X-Fi XtremeMusic, SB0450 can connect to SB0250. Are there any other X-Fi sounds cards that can connect to the SB0250 and can anyone confirm this? I'm going to throw this into an XP box. Thanks!
Audigy 2 Breakout Box SB0250 download/file.php?mode=view&id=186004
    216.23 KiB
Still Can't Crysis ~ WinXP Core 2 Duo e8600 + NH-D15 /w NM-i3 kit ~ Titan X 368.81 SLI... ~ Audigy 2 SB0250 + Hub ~ nForce 680i SLI ~ 2021 RMx 1000 ~ DDR2 4GB ~ 480 SSD ¬
Sleeper Dell Dimensions 4100 & V400 Fedora build ¬
Reply 1 of 2, by darry
BawlsTowers wrote on 2024-02-21, 03:42:
The SB0460 (XtremeMusic) is probably what you mean, rather than SB0450 .
Essentially, any PCI (not PCI Express) X-FI card that has a 40-pin header should work.
Beware of OEM variants : Re: Front Panels Compatible with Sound Cards with EAX for WXP
Reply 2 of 2, by BawlsTowers
The XtremeMusic and I think, XtremeGamer would work as well. They have the 40pin connector. Maybe they are both SB0460. I'm getting a bit confused with how people are labeling these cards online.
You said that it must be a PCI sound card, because none of the PCIe cards have the 40pin connector? I did see that with the X-Fi Titanium as well.
How do I know I am not looking at an OEM card? The model number should be SB0460 and nothing else? I'll include a few photos. All of these are definitely a real SB0460 card, right? If it says Creative Labs SB0460, then that is what I am looking for? Is there anything else I need to consider.
    1.23 MiB
    509.29 KiB
    1.23 MiB
    353.15 KiB
