Reply 200 of 272, by myne
Ah.
Glad I left that line in the script. (the 3rd line of your screenshot)
This should do it.
Things I built:
Mechwarrior 2 installer for Windows 10/11 Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 201 of 272, by ChronoReaperX
myne wrote on 2024-02-15, 03:25:
Ah.
This should do it.
I have tested 2 different copies of MW2 31st CC Titanium but it still failed to install as you can see in the screenshots attached:
Reply 202 of 272, by myne
My bad on one of those.
Both should work now unless I'm blind to typos.
"TITAN_MW2-TITMW2W95-MW2 Titanium Edition" {$CDDRIVE =$letter; $edition="TITMW2W95"; break findcd}
"TITAN_MW2-TITW95-Titanium Trilogy" {$CDDRIVE =$letter; $edition="TITMW2W95"; break findcd}
Things I built:
Reply 203 of 272, by myne
ChronoReaperX wrote on 2024-02-15, 04:34:
Did it work?
Things I built:
Reply 204 of 272, by ChronoReaperX
myne wrote on 2024-02-15, 04:43:
My bad on one of those. Both should work now unless I'm blind to typos. […]
After extensive testing, I can confirm now that all works almost perfect! Thank you to Myne and Been_Nath for giving a quality of life to one of the most legendary simulation game in PC history (and the most annoying because of so many different versions out there).
SALAM (PEACE) FROM MALAYSIA
Reply 205 of 272, by myne
Sama-sama
Cheers for your patience and help adding the extra editions.
Things I built:
Reply 207 of 272, by GrampaGotTheKeys
Really cool project! Wish I knew about this sooner!
Only problem i'm having atm is detecting the two copies of Mercs I use:
    37.82 KiB
Reply 209 of 272, by myne
I'll try get to it on the weekend.
If you can't wait, have a read of this:
It shouldn't be too hard to figure out
Things I built:
Reply 210 of 272, by myne
In theory both should work with this
Unless they're a quirky edition
Things I built:
Reply 211 of 272, by GrampaGotTheKeys
myne wrote on 2024-02-23, 06:12:
Thanks for the quick reply, didn't work, had a peek into the changes and there was a spelling error in the new lines:
"MERCENARIES-MercsW95-Merecnaries" {$CDDRIVE =$letter; $edition="MercsW95"; break findcd}
"MERCENARIES-MD3DW95-Merecnaries D3D" {$CDDRIVE =$letter; $edition="Mercs3DSW95"; break findcd}
After changing "Merecnaries" to "Mercenaries" they were detected and installed!
Bad news is I'm having this weird problem (this is effecting D3D, 3DFX, all versions of them!) the games can start up into the menus fine BUT display this error when trying to start a mission, this didn't happen before:
    35.25 KiB
Reply 212 of 272, by BEEN_Nath_58
GrampaGotTheKeys wrote on 2024-02-23, 16:15:
Thanks for the quick reply, didn't work, had a peek into the changes and there was a spelling error in the new lines: […]
Ah there we go. I digged into this error earlier, but I no where found what caused this. I couldn't find any responsible registry key either.
The problem wasn't happening when I did the actual CD installation through InstallShield Wizard. If you want to go through that, its present in my first post
Reply 213 of 272, by myne
Ah. Typos. My bane.
So the menus work?
What happens after you change the resolution?
If it works, then look in regedit for Activision, mercenaries and send me the details in that key so I can add it
Things I built:
Reply 214 of 272, by GrampaGotTheKeys
myne wrote on 2024-02-23, 23:18:
OH well looking at the regedit clued me in that no settings changed were being saved, everything was just sitting at default.
After setting the shortcuts to run as admin I could finally change resolution and other settings! The 3DFX & D3D versions run great now! 😀
BUT the standard win95 edition still refuses to start any missions (The menus & movies still work though)
On a side note, anyone else having major FPS drops when the setting "Particles" is on?
Here's what the regedit was looking like by default:
    148.66 KiB
Reply 215 of 272, by myne
Ah interesting.
Wonder why it can't update reg without admin.
Interesting that it's in WOW6432
What that means is "Windows on Windows 64bit 32bit
So it's a kinda virtualisation subkey. On ye old windows 9x it's NOT in that area at all.
Are they running within DGvoodoo in a much higher res?
The 9x version might be one of those unique editions that doesn't work with that install method I wrote and chose.
I'd have to have a copy to figure it out.
The reg keys should be somewhat straightforward, but it does mean we have to figure out the Mw2 GBL and mercs keys - and any subversions eg 1.1, 1.5 etc
So a whole new layer of potential annoyances.
re-uploaded the above installer with the typos fixed.
Things I built:
Reply 216 of 272, by myne
If you're not scared of the registry...
Backup that key to a reg
Delete it
Then try this from powershell and see if it works:
New-ItemProperty -Path HKLM:\SOFTWARE\Activision\Mercenaries 3D\1.0\ -Name "Display Width" -PropertyType Dword -Value 00000280
New-ItemProperty -Path HKLM:\SOFTWARE\Activision\Mercenaries 3D\1.0\ -Name "Display Height" -PropertyType Dword -Value 000001e0
Things I built:
Reply 217 of 272, by myne
Actually, scratch that.
I changed it so all the shortcuts are created with the admin flag set.
Theoretically, it should fix all of the variants with that error.
Beennath are you able to confirm the one you had that didn't work now does (once you set the resolution)
    mw2Installer.zip
    4.25 MiB
    52 downloads
Things I built:
Reply 218 of 272, by BEEN_Nath_58
myne wrote on 2024-02-24, 05:56:
Actually, scratch that. I changed it so all the shortcuts are created with the admin flag set. […]
Give me 3 days. I can't access the game until then nor test it
Reply 219 of 272, by GrampaGotTheKeys
myne wrote on 2024-02-24, 03:20:
Oh I forgot I still had virtualisation on, after turning it off still having the same issues even after trying to reinstall mercs, puts the keys in the expected place now at least:
    107.85 KiB
