First post, by airbone-x
Hello Folks,
please anybody has a pinout for MoBo PC CHIPS M726 / Bxcel PC100 Slot1, on-board, so called "ATX FORM CARD CONNECTOR" ? That thing is probably not easy to purchase from anywhere and I was wondering to connect PS/2 mouse directly to the header pins. On otehr site suggests that it should be identical as on some Asus boards, but that pinout did not work for me. I am getting power to the mouse, but it does not respond and win98 says no mouse found. I tried to swap CLOCK and DATA either way but no difference. Or maybe it would not work without that card connector by direct connection, as it seems that this card connector has some additional smd passive components like resistors/smd caps etc? Anybody has experience or with similar board? Or if anyone in europe has compatible atx form card connector he could sell? Thank you.
