First post, by fgh
Hi there,
I've had a GUS ACE and an MT32 for years and used them with an AWE64 in my 486 and later a P233MMX. It’s been a lot of fun!
Now I have a different project with some unusual limitations, and I want to use the ACE and MT32 on this machine, along with a second card with good SB compatibility.
The unusual limitation is: I need a non PNP card with an IDE port to replace the AWE64. ('Semi PNP' SB16 would be ok)
So, what non PNP cards with IDE would you recommend?
Ideally it would have a real OPL3, decent SNR, no hanging note bug (at least type 1) and Intelligent mode for the MT32.
But I suppose I can't have it all. (At least I don't need a wavetable header or a volume knob! 😀 )
The reason it cannot be PnP is it will be booting off the sound card IDE (with the clever XTIDE Universal Bios).
I have an MPU401 card but this project is too limited in ISA slots for both it and the GUS. And I really like the GUS, so I hope to keep using both it and the MT32, even without the MPU401.
I've seen from this site that there are ~13 SB16 variants with IDE that are non/semi PNP: www.dosdays.co.uk/topics/sb16.php
Most have either the noisy DAC or both hanging note bugs - it seems CT2290/2291/2299 might be the best SB16 models for this..
But are there other cards that fit the bill as well? I'd be happy to have a non creative card.
Thank you! 😀
