SB 16 CT1790 vs CT2230
First post, by RagingSquirrel
Hi i have a question regarding these two sound cards. I want to buy one of these for my 486 rig mostly for old dos and win 95 games ... and i am not sure which one is the better for this case.. I could get the CT2230 slightly cheaper. What i noticed that both got opl chip on it, but while the 1790 has a Yamaha one the 2230 has a creative opl chip. I am not sure which one is the better, also is it matter at all in my case?
Reply 1 of 22, by Grzyb
Sound Blaster: From best to worst
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 22, by RagingSquirrel
Grzyb wrote on 2024-03-20, 13:36:
Thank You .. i saw the excel board but it still doesn't explain the difference between the two types of opl chips.. or in fact it doesn't even says which one is the better.. it is just a list but in numeric order not in quality order..
Reply 3 of 22, by Grzyb
CT1747 contains licensed OPL3 circuit - I think no difference here.
Reply 4 of 22, by TheMLGladiator
Do you plan on using an external synthesizer/daughterboard? If so, see if you can check the DSP version on the CT1790. If it is 4.04 or 4.05, it should be free of the hanging note bug. Otherwise, I would stick with the CT2230, since it is cheaper and is most likely less noisy.
More info here: Sound Blaster 16 Bugs and Deficiencies Summary
Reply 5 of 22, by MadMac_5
I have a CT2230 with the Creative-branded OPL3, and to me it's pretty much indistinguishable from the Yamaha-branded ones I've used in the past. TIE Fighter, Tyrian, Doom, and Duke 3D all sound very similar to other OPL3 captures that I've heard in the modern era too.
Reply 6 of 22, by RagingSquirrel
TheMLGladiator wrote on 2024-03-20, 14:43:
No i only want it to use it for dos and win 95 games ..
Reply 7 of 22, by RagingSquirrel
Hi.. just a little update i am about to buy the CT 2230 .. so i found this driver on the side for the same model ,
http://vogonsdrivers.com/getfile.php?fileid=1135&menustate=0
but i am not sure what asp means? Is this an official driver should i use this or find an other one ?
Reply 8 of 22, by MadMac_5
The ASP is the Advanced Signal Processor, which was an optional add-on for the card that let it do some real-time effects to sounds. Not much software ever used it, and your card likely doesn't have the ASP chip installed. The drivers you found will work just fine with the CT 2230.
Reply 9 of 22, by RagingSquirrel
MadMac_5 wrote on 2024-03-21, 14:17:
Thank You
Reply 10 of 22, by RagingSquirrel
I am getting the card tonight.. I am wondering that under Windows 95 i just have to install the driver , but how can i install it for dos , and Win 3.11 .. As i heard i have to edit autoexec.bat file am i right? Can someone help me out of it please..
Reply 11 of 22, by auron
the CT2230 has jumpers to set the i/o ports (by default 220h for the SB16 part and 330h for the MPU-401 part), while DMA and IRQ are configured in software. if you reboot from win95 to DOS you shouldn't have to do anything, provided your SET BLASTER line in autoexec.bat matches whatever resources are allocated in win95.
for booting straight to dos, run diagnose.exe /s to initialize the card with the parameters in SET BLASTER, or just diagnose to select the resources yourself. win3.11 will need a seperate driver.
Reply 12 of 22, by RagingSquirrel
auron wrote on 2024-03-22, 18:34:
Sorry for the stupid question , but where can i find diagnose.exe file?
Reply 13 of 22, by auron
if it's not part of your driver package, grab the s64basic.exe file mentioned in this thread: AWE32/64 DOS utility versions
Reply 14 of 22, by Joakim
You can also use unisound driver if you like. It is very easy to setup.
Reply 15 of 22, by RagingSquirrel
Hi .. i got the card.. and i think i might be scammed.. because i put the card in a isa slot and boot up Win 95 , but it did not detect any new device.. i know its not a pnp device but it should show up in device managger automaticly.. right?
Reply 16 of 22, by exobot
I haven't used 95 in a while, but I don't think so? In 98 you can do a manual search for non-pnp hardware from the install new hardware option in Control Panel, I would imagine 95 is similar.
Reply 17 of 22, by Grzyb
No.
If it's not PNP, it's not detected on boot up.
It may be detected during installation, but if Windows is already installed, you have to use "Add new hardware", or something...
Reply 18 of 22, by RagingSquirrel
yes i figured it out.. i had to use add hardware manually now it works.. just one small problem that under doss it really loud .. how could i reduce the master volume under dos?
Reply 19 of 22, by RagingSquirrel
ok i figured out i had to set the master level, by running mixerset.exe
