Reply 963 of 3329, by BEEN_Nath_58
sharangad wrote on 2024-04-07, 15:54:
@BEEN_Nath_58
Does the end credits clip of team apache work properly in d3d mode?
I will check, but I have a similar situation as Raven where a storm blew away the electricity 🙁
Reply 964 of 3329, by sharangad
Aargh! What's the world coming to.
Well at least you're still in one piece like @Raven-05. That's no longer something most people can take for granted anymore.
Can't wait for both of you to get back on the job.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 965 of 3329, by RaVeN-05
sharangad wrote on 2024-04-07, 01:26:
@Raven-05 when the power comes back, if it's not too much of a hassle, can you post a video of ICR 2 crashing or running into into the barriers on the Australia track? I need to see what the dust/impact particles are supposed to look like.
https://fex.net/s/tmmxaev
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 966 of 3329, by sharangad
Yaay! You're back!
Thanks. The impact particles are mostly correct. I don't have any dust particles. I'm guessing that's because there're no grassy bits on the road. The chroma keying is also wrong and the hud/indicator on the top left is showing the wrong texture.
Reply 967 of 3329, by sharangad
Hopefully @BEEN_Nath_58 can verify whether the end credits in team apache is a clip issue or an rready one.
[EDIT] If it is a clip issue maybe he can fix it.
Reply 968 of 3329, by RaVeN-05
also little recommendation cvars for quake and quake2
r_clearcolor 0
v1k_clearcolor 0
0 - is black color, where nothing to draw, makes some custom maps to be less noticeable glitches on them.
or while you noclipping )
Reply 969 of 3329, by sharangad
RaVeN-05 wrote on 2024-04-07, 20:43:
also little recommendation cvars for quake and quake2 r_clearcolor 0 v1k_clearcolor 0 0 - is black color, where nothing to draw, […]
r_clearcolor 0
v1k_clearcolor 0
That should already work. When clearing the back buffer it should use that colour. I'm guessing it doesn't work for some reason.
Reply 973 of 3329, by sharangad
This should disable vsync correctly in vquake 2. Team apache should run just fine.
https://1drv.ms/u/s!As-dKk-N73dSmGjNiZdzKiiMBkXT?e=LDZGld
MD5: a6c7053b53e077c50d88f482a3826266
v1k_clearcolor should just work. Not entirely sure why it isn't working.
[EDIT] Or did you mean the cvar helps? With quake 2 it's already set to 0
Reply 974 of 3329, by BEEN_Nath_58
sharangad wrote on 2024-04-07, 20:34:
Can you explain where to access the end credits? There is a "Credits" section in the game; it works both in RReady as well as DX modes.
There is one problem I saw: when exiting the mission to the menu, the game doesn't Refresh the menu
Reply 975 of 3329, by robertmo3
BEEN_Nath_58 do all three logos/intros when you start the game run correctly for you too?
Reply 976 of 3329, by sharangad
Exiting the missions prevents screen updates for some reason. They're drawn to the front buffer.
Yeah th
E credits section is what I'm talking about. On my system it freezes and macro-blocks appear. It used to work perfectly. Maybe my hard drive is in a bad way. I keep the corrected iso on a hard drive.
Reply 977 of 3329, by RaVeN-05
vquake2 fix also touch hexen2 , they probably need to be separated somehow, both not working when r/v1k_nopageflip used.
i mean to add to autoexec.cfg this r/v1k_clearcolor 0 , yes those cvars works, its just recommended to use 0 instead of their current values.
Reply 978 of 3329, by sharangad
RaVeN-05 wrote on 2024-04-08, 08:07:
vquake 2 should be working. Is it not. I'll test hexen.
Reply 979 of 3329, by BEEN_Nath_58
sharangad wrote on 2024-04-08, 07:24:
Yeah th
Well the game runs a little slow than what I would expect, the video has microstutters too. There are graphical glitches with the mouse too, from the start of RReady development
