How to get and validate DMA mode for disks in Windows 3.1?
Reply 60 of 69, by pshipkov
I think the two cards are identical.
Just the SIIG one has stickers over the same chips.
As impressive the Holtek VLB EIDE controllers are, their ISA stuff is not like that.
In reasonable ISA frequency they are the same as everybody else.
Dont handle well ISA overclock.
Recently i checked HT6550.
retro bits and bytes | DOS media library
Reply 61 of 69, by douglar
pshipkov wrote on 2024-05-29, 04:18:
Definitely no Holtek chip on the card that I have. It’s just a sticker over unpopulated contacts.
Reply 62 of 69, by pshipkov
Right. Had to look again at the oic you provided.
So that ht6535 seems to be the LPT implementation actually.
Reply 63 of 69, by douglar
pshipkov wrote on 2024-05-30, 05:06:
Ahh. I see that the card with the HT6535 chop has additional LPT headers. The second LPT chip makes sense now. Thanks for helping me out there.
So my only remaining question is: "what is that 2KB SRAM chip doing" ?
Wouldn't there need to be some sort of IDE controller on the card if it was going to use a buffer?
Reply 64 of 69, by mkarcher
douglar wrote on 2024-05-30, 17:31:
Likely the 2K SRAM chip is visible in the ROM window of the card, and will be used by the IDE BIOS to store the drive geometries. Possibly only a small amount (like 64 bytes) of the chip is accessible, as that's all you need for that stuff.
Reply 65 of 69, by douglar
mkarcher wrote on 2024-05-30, 17:42:
That sort of makes sense. The only nagging through is that it would have been less expensive to steal 2KB bytes of conventional memory. Why add a chip when you don't have to?
Here's the back of the card.
The attachment SC-JEE012 back.jpg is no longer available
Reply 66 of 69, by pshipkov
The 2Kb buffer is too big for what mkarcher speculated and too small for data cache.
It probably is for instructions cache to avoid the need of ROM shadowing through mobo bios.
Some SCSI controllers from that time do the same.
Reply 67 of 69, by jakethompson1
ECP parallel ports include support for a FIFO buffer; could it tbe that?
Reply 69 of 69, by pshipkov
The SRAM chip is present in both cards, where one of them has the Holtek LPT IC + header and the other does not.
So, it is unlikely the SRAM buffer is LPT related.
It is not clear from the pictures how and where the SRAM pins are connected.
Looks like on the front quite a few of them go to the EPROM.
Anyhow.
