VGA to HDMI converter
First post, by M95D
Hi.
Due to lack of space I had to replace my two 21" CRTs with an ordinary TV that is also used as PC monitor. I need a VGA to HDMI converter in order to use my vintage PC. Unfortunately, most of them do not support low DOS resolutions / refresh rates. Or maybe the TV doesn't?
Please recommend me a VGA (D-SUB) to HDMI converter/rescaller that is known to work with low resolutions.
As an alternative, I could find the space for a very small display (10" or less) that I could install only when I play with DOS. There are several models on aliexpress, but they don't say supported resolutions or clock frequencies (rember those?).
Do you know of any models that are known to work?
As a 3rd alternative, I could use a VGA to composite video, S-Video or YPrPb converter. Any recommendations?
Thanks.
Reply 1 of 11, by dominusprog
Purchase a VGA to HDMI scaler.
https://www.amazon.com/StarTech-com-VGA-HDMI- … 18371113&sr=8-8
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 11, by M95D
The lowest listed resolution is 640X480. I need 320x200.
Reply 4 of 11, by jmarsh
M95D wrote on 2024-06-14, 15:46:
No converter is going to handle 320x200, because that's not what gets output by the card - it gets line-doubled to 400 and the horizontal pixels aren't tied to a clock so to a display device, 320x200 appears the same as 640x400.
What you really need to pay attention to is the converter's ability to handle 70Hz input...
Reply 5 of 11, by wbahnassi
I use OSSC to upscale VGA and connect to LCD via HDMI. It will line-double the DOS resolutions and pass-through higher ones that your monitor can natively handle. Plus it can add scan-lines, so very close to a CRT.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 6 of 11, by M95D
OSSC seems the best option and it's not very expensive.
Reply 7 of 11, by M95D
Does OSSC support refresh rate conversion? 70Hz to 60Hz or lower? I can't find anything about this on their wiki page.
Reply 8 of 11, by Tiido
It does not, framerate will remain as what came in. Only the vertical resolution can be multiplied with primary intent is to line double 240p/288p sources from old game consoles so they fit the limits of VGA monitors and modern display devices.
320x200 in PC stuff is line doubled by the video card and to the monitor etc. it is a 400 line source at 70Hz for games that don't try to reprogram display timings.
The most likely issue is that the TV just doesn't support 70Hz input although it can be the VGA to HDMI dongle doesn't either. You should try to see if that TV will sync to any higher refresh rates using a modern PC over the HDMI output. It should be possible to already select higher refresh rates or make custom resolutions with increased framerate for this and rule out TV being the limiting factor.
Reply 9 of 11, by Imperious
My old Dell U2412 monitor worked perfectly with all Dos resolutions including 720x400 70hz and also You could force 4:3 aspect.
I now have a 144hz LG LCD and it will not show 720x400 70hz Dos resolutions. If Your monitor cannot do 70hz at all, even in Dos then the OSSC will not help.
I use the OSSC with my LG monitor as the vertical resolution can be line doubled and that works.
You have to do quite a bit of tinkering with the settings to get a proper 4:3 aspect ratio image on a 16:9 monitor, but You can save up to 15
profiles.
I Also use it for my C64, Spectrum 2+, Amstrad CPC, Amiga 500 as they all have RGB output. RGB2HDMI is no good as it only supports 32 Colours maximum (ok for CGA and EGA).
Those Startech units are probably best avoided. I got a NOS one a few years ago and it doesn't work with 720x400 and also it forces a Black level of 16
with no option to select 0. That's why The image a few posts above is brighter than it should be.
A s far As I know there is no way to downgrade the firmware and I don't think the firmware is available anywhere even if You could.
Reply 10 of 11, by wbahnassi
Yeah OSSC doesn't change refresh rates. I believe LCD monitors should all support DOS modes though (70hz)... TVs OTOH don't typically expect such refresh rate unless the TV itself is designed to take PC input (quite a few TVs advertise it).
Reply 11 of 11, by jmarsh
wbahnassi wrote on 2024-06-24, 05:58:
"Support" them by skipping rendering of 1 frame out of every 7, yes...
