First post, by ux-3
My old Diamond Monster 3D is giving me some trouble:
If I run the 3dmark99 race test, it will freeze in the first or second round. Always at one of the same two locations. It dislikes the second corridor test too.
If I use 3dmark99pro, it will run the race test (which is a bit different, more features, runs slower). But if I run it long enough, so that the card heats up much, it will start to have the occasional triangle or texture flicker. Something definitely changes when the card gets hot (and it inevidably does).
I can observe this on a 233@66 Pentium mmx and on a Pentium II 400@100.
I would suspect that this isn't regular behavior, but that something fails subject to the heating. Not sure though, as this was leading edge technology at the time.
The effect of card clock speed seems to be "heat only". If I run the test at 60 MHz, I get the triangles etc. faster. If I then drop to 40 MHz, they will still show.
Can someone diagnose this or suggest a cure?
I will try a regular game and see how that goes. I need to heat up the card first for quick results I guess.
Any ideas would be welcome.
Retro PC warning: The things you own end up owning you.
