First post, by ux-3
My old Diamond Monster 3D is giving me some trouble:
If I run the 3dmark99 race test, it will freeze in the first or second round. Always at one of the same two locations. It dislikes the second corridor test too.
If I use 3dmark99pro, it will run the race test (which is a bit different, more features, runs slower). But if I run it long enough, so that the card heats up much, it will start to have the occasional triangle or texture flicker. Something definitely changes when the card gets hot (and it inevidably does).
I can observe this on a 233@66 Pentium mmx and on a Pentium II 400@100.
I would suspect that this isn't regular behavior, but that something fails subject to the heating. Not sure though, as this was leading edge technology at the time.
The effect of card clock speed seems to be "heat only". If I run the test at 60 MHz, I get the triangles etc. faster. If I then drop to 40 MHz, they will still show.
Can someone diagnose this or suggest a cure?
I will try a regular game and see how that goes. I need to heat up the card first for quick results I guess.
Any ideas would be welcome.
Retro PC warning: The things you own end up owning you.
Reply 1 of 10, by swaaye
Look very closely for any bent pins on the 3DFX chips that might be in contact with a neighboring pin or have broken soldering. The RAM chips may also have broken soldering.
Reply 2 of 10, by Gmlb256
Regarding thermal issues, adding heatsinks to the TMU and FBI chips on Voodoo cards helps.
Reply 3 of 10, by ux-3
I did run the Tomb Raider 3D Demo on Diamond Monster CD. Looked fine.
I also applied pressure to all bigger chips while the card was running hot and 'triangulating', but nothing noticably changed.
Reply 4 of 10, by ux-3
Today, I had another look at the card and I noted something peculiar, compared to the Voodoo². My Voodoo 1 gets HOT when it does nothing. The medium sized chip on top gets too hot to touch while the card is minding it's own business. The Voodoo² chips get warm in idle. But nowhere hot. If there are V1 owners around, could you please check if your cards get really hot in idle?
I have looked over the whole card with a +3 pair of reading glasses, but it looks like new.
Sound to me as if either the voltage is too high or if some signal is alway active.
Reply 5 of 10, by sdz
It's normal for the TMU to get quite hot while in idle. Voodoo2 lowers the FBI/TMU clock significantly while in idle (usually 30MHz) , V1 doesn't do that.
The only power rail on the card is the 5V one. There is no regulation on the card, this comes directly from the PCI slot. Maybe check with a multimeter the 5V rail in your PSU.
Even if your card looks perfectly fine, try poking all the FBI/TMU pins with a needle. I had cards that looked fine even under the microscope, but some pins weren't actually connected.
Reply 6 of 10, by ux-3
sdz wrote on 2024-06-20, 21:28:
OK, so the chip being hot is not a symptom of the problem, but perhaps the trigger. Maybe due to thermal expansion?
Does it make sense to lower the card frequency to the min of 16 MHz while not using it? So that it doesn't literally glow in the dark all the time and heat up the neighbors?
As I have this issue with the card on various machines, I can rule out the 5V line. I even measured PSU voltages to check that end.
Poking leaves a lot of room for interpretation. So I take a steel needle and then do what? Try moving pins left and right by pushing a needle into the gap between pins? Try lift them? How much force is enough to test but not to cause the issue?
As the upper chip is the hottest, I would start there.
Reply 7 of 10, by ux-3
I did. Pushed a needle tip between the pins and slowly moved it downward until it got stuck. I expected a loose pin to move sideways at the bottom, but none did.
However, the card has stopped triangulating for now. It seems to be working OK again. Nice. Thanks for the idea.
Reply 8 of 10, by rasz_pl
ux-3 wrote on 2024-06-21, 19:23:
That would suggest you didnt notice a loose pin, but moving it made the connection temporarily stronger. Proper solution is resoldering all pins. Another option is loose connection on one of ram chips.
Reply 9 of 10, by ux-3
rasz_pl wrote on 2024-07-03, 20:05:
Too many, too risky. Should the problem return, I will repeat the procedure, but with only half a side of one chip. Then test again. That way, I can hopefully nail it down to a few pins and resolder those.
Reply 10 of 10, by rasz_pl
ux-3 wrote on 2024-07-03, 20:52:
Its the other way around, leaving dangling pins and hoping just wiggling them will somehow fix it will eventually lead to latch up (https://en.wikipedia.org/wiki/Latch-up) and fry your voodoo. Resoldering both chips and ram for good measure is the only proper course of action.
