First post, by Galova
I've got a PCI sound card with Yamaha YMF724 chip onboard which is good for DOS gaming.
It can be also used to play Yamaha XG-MIDI format files as this chip allows both OPL3 in DOS and Yamaha wavetable synthesis close to DB50XG daughterboard and MU-50 tone generator I believe. Yamaha softsynthesizer S-YXG50 in both virtual driver and VSTi plugin incarnation share same synth engine, wavetable and General MIDI plus XG-MIDI functionality.
I know that this device should support SPDIF output as it uses Yamaha PCB reference design obviously, but this particular soundcard PCB is not fully populated.
It seems to have all the traces and soldering pads needed as well as PCB mask indicating which part should be and where. But these parts are not soldered, because the manufacturer simply ignored them.
Part names and values are unknown either. I can only read some marks and guess. R goes for resistor, C goes for capacitor etc.
SPDIF output option can be found in Windows driver control panel but there is no way to use it of course, because corresponding electronic parts are not populated on the PCB.
Soundcard analog output sound quality is far from good and I wish I could use digital output.
I would possibly use my soldering skills to get and set all needed parts in place to make SPDIF work but I couldn't find any info which parts should be there on the Internet.
I believe there must be experienced people around who might know typical schematics and some other details like part values etc in order restore the SPDIF output interface.
I have taken fine quality hi-res pictures of the soundcard front and back side to be specific.
front side is provided as is, the back side picture is mirrored (like it should be seen through the front side)
