First post, by Galova
I've got a PCI sound card with Yamaha YMF724 chip onboard which is good for DOS gaming.
It can be also used to play Yamaha XG-MIDI format files as this chip allows both OPL3 in DOS and Yamaha wavetable synthesis close to DB50XG daughterboard and MU-50 tone generator I believe. Yamaha softsynthesizer S-YXG50 in both virtual driver and VSTi plugin incarnation share same synth engine, wavetable and General MIDI plus XG-MIDI functionality.
I know that this device should support SPDIF output as it uses Yamaha PCB reference design obviously, but this particular soundcard PCB is not fully populated.
It seems to have all the traces and soldering pads needed as well as PCB mask indicating which part should be and where. But these parts are not soldered, because the manufacturer simply ignored them.
Part names and values are unknown either. I can only read some marks and guess. R goes for resistor, C goes for capacitor etc.
SPDIF output option can be found in Windows driver control panel but there is no way to use it of course, because corresponding electronic parts are not populated on the PCB.
Soundcard analog output sound quality is far from good and I wish I could use digital output.
I would possibly use my soldering skills to get and set all needed parts in place to make SPDIF work but I couldn't find any info which parts should be there on the Internet.
I believe there must be experienced people around who might know typical schematics and some other details like part values etc in order restore the SPDIF output interface.
I have taken fine quality hi-res pictures of the soundcard front and back side to be specific.
front side is provided as is, the back side picture is mirrored (like it should be seen through the front side)
Reply 1 of 18, by Tiido
You need to populate C18, R21, R22, CB2 and T1 to get a proper Coax SPDIF output capability.
C18 and CB2 values are not critical, both can be 0.1µF. R21 and R22 depend on exact pulse transformer used, but likely in the vincinity of 75 ohm.
If you need Toslink you need to find some 5V transmitter, wire up power and get TTL SDPIF signal for its input from the lower pad of C18.
Reply 2 of 18, by Galova
Tiido wrote on 2024-07-02, 06:07:
Coax SPDIF will do just fine. What kind of pulse transformer it might be? I guess it's indicated with a big square next to SPDIF unsoldered connector in the top right corner, correct?
If you mentioned optical by Toslink I wonder where do I get TTL signal? What kind of 5v transmitter? Unfortunately I'm not familiar with this sort of electronics. I know basics but not this particular topic, it is out of my knowledge. I'm not familiar with digital devices. Analog mostly.
I also wonder what U3 and U7 also not present on the PCB could be and what its purpose.
Reply 3 of 18, by Tiido
For all intents and purposes this is all analog domain stuff. You got 5Vpp and ~6MHz squarewave signal that needs to end up as galvanically isolated ~1Vpp 75ohm impedance signal with as rectangular shape as possible. There are dedicated SPDIF pulse transformers, and this card likely used one of them. I don't know any of the part numbers that would fit the existing footprint. I did mention the exact spot where the signal comes out of...
U3 is an EEPROM, for holding conf info. Perhaps to hold PCI subsystem ID for OEM solutions or something.
U7 is alternative to U4, you use one or other depending on parts at hand.
EDIT: Fixed SPDIF signal level, it is 1Vpp in the coax.
Reply 4 of 18, by Galova
Tiido wrote on 2024-07-04, 19:59:
For all intents and purposes this is all analog domain stuff. You got 5Vpp and ~6MHz squarewave signal that needs to end up as galvanically isolated ~0.5Vpp 75ohm impedance signal with as rectangular shape as possible. There are dedicated SPDIF pulse transformers, and this card likely used one of them. I don't know any of the part numbers that would fit the existing footprint. I did mention the exact spot where the signal comes out of...
well my guess is that signal goes out of a rivet hole near J19 from the back side of the PCB and goes to C18 which must be filtering out DC component. R21 should attenuate somehow transformer input. CB2 probably cleans out EMI or something that may appear in transfrormer windings. R22 adopts what is left to SPDIF standart. Just guessing. need some research of dedicated pulse tranformers that may fit
Reply 5 of 18, by Galova
Galova wrote on 2024-07-07, 20:26:
well my guess is that signal goes out of a rivet hole near J19 from the back side of the PCB and goes to C18 which must be filtering out DC component. R21 should attenuate somehow transformer input. CB2 probably cleans out EMI or something that may appear in transfrormer windings because it goes to a ground plane obviously. R22 adopts what is left to SPDIF standart. Just guessing. need some research of dedicated pulse tranformers that may fit
Reply 6 of 18, by Galova
By the way. About pulse transformer. Is it 1:1 or step-down?
Reply 7 of 18, by Tiido
Probably 1:1, but you can use other stuff by adapting the resistors.
This looks like it might fit the footprint : https://no.mouser.com/ProductDetail/Pulse-Ele … yrwjtKK7g%3D%3D
Reply 8 of 18, by Galova
Tiido wrote on 2024-07-07, 20:59:
Oh thanks, should take a look at it.
I think I need to take oscilloscope and check if there is any signal at all. Who knows.
Reply 9 of 18, by Grem Five
I'm not sure what is exactly going on in this picture but I found it while surfing on this subject.
Reply 10 of 18, by Tiido
That particular mod seen puts 5Vpp directly on the coax and there are devices that will die in such a condition, such as ESI Juli@ on which I actually fried the SPDIF input this way and had to replace a chip (and conjure up a protection circuit too). Coax has near 1Vpp level on it and devices don't necessarily handle beyond that. Other aspect is that the logic signal that outputs the signal is not meant to drive a 75ohm load and can get damaged from it also. The very least it will need a series resistor of about 330 ohms so that the 75ohm in the receiving end forms a divider that gives close to expected 1Vpp and also reduces load on the logic output on transmitting side. But since the impedance is not quite right, longer cables are probably not gonna produce an output, nor will there be galvanic isolation so there's ground loops potential and that can manifest in variety of ways too, including the SPDIF connection itself not functioning.
Reply 11 of 18, by Galova
I have read that SPDIF carrier frequency is somewhat around 3 MHz and 1V peak to peak.
If the signal generated by yamaha chip is 5Vpp then 1:1 isolating transformer doesn't meet specification, as it should be stepdown 5:1 this case. Output impedance should be 75R as well as transmitting coax cable impedance. Somewhere inside of SPDIF recording device input terminal should be at 75R as well.
Forgive my ignorance, I may be wrong.
As for the picture above I don't think one can simple throw away the transformer and use such connection as it may be unsafe for receiving device. I don't think galvanic isolation is kept in mind here just for lulz
Reply 12 of 18, by Tiido
The frequency depends on sample rate. SPDIF has 64 bits per sample in each data frame which is then manchester encoded. I had misremembered that it doubles the frequency but it can work inside existing frequency since it only changes when the bit flips within the same clock period. YMF724 has locked 48000Hz sample rate so the output is 480000 * 64 = 3.072MHz. But yes, 1Vpp into 75ohm load with 75ohm line impedance.
Ideally there's a voltage divider before the transformer as I see in many application manuals of various digital audio chips but this particular card seems to just yolo it and rely on whatever winding resistance and those external resistors produce. Impedance will be wrong even if the output level is right, but unless you have long cables it won't really matter. This is not a Yamaha made card or even a reference design, if there's a reference design it is Yamaha Waveforce 192XG sound card. That one doesn't even have the SPDIF exposed on it 🤣.
Reply 13 of 18, by Grem Five
Tiido wrote on 2024-07-08, 16:57:
The Yamaha Waveforce 192D has an optical out although its a different pcb layout
Funny thing is For that Labway card they list the spdif as an option but I have never seen a spdif actually populated on the a301-g50.
Reply 14 of 18, by Tiido
I didn't even know there was a 192D, but I found a VOGONS port about it with photos : Re: Question about the Yamaha Waveforce WF192D SPDIF.
Optical output is easy, you just wire up power and the TTL signal to the transmitter module and you're done, no transformers or anything else to worry about.
Reply 15 of 18, by slivercr
Hate to necro, but I was recently donated a pile of electronic parts which, among other things, had a small tube with 10 or so PE-65612NL. I did a test fitting and it fits exactly in place. I need to source the SMD resistors/caps before I solder anything, but I was wondering if this transformer would do?
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 16 of 18, by Tiido
It looks like it is specifically made for SPDIF use so I imagine there won't be any problems using it for this task.
Reply 17 of 18, by slivercr
Tiido wrote on 2026-02-25, 17:46:
Thanks Tiido!
Is the cap before the transformer necessary? If not, I'm thinking I could
  • Cut red
  • connect bottom of R21 to pin2 of transformer (Yellow),
  • connect top of R21 to ground on top (Black) (would it be better with a small cable directly to pin1 of transformer?),
  • Populate C18 and R21 with resistors to get a 1Vpp signal
  • Populate CB2 and R22 with the values you suggested on a message above.
The attachment voltDiv.png is no longer available
Reply 18 of 18, by Tiido
C18 is there to prevent DC from saturating the core but that shouldn't really be a problem. It is better to have it rather than not have it and I think I would just measure DC resistance of the transformer and use it to calculate what R21 value should be for ~1V result.
