First post, by mita
I got this 286 MBoard with PC Chips 82c206,211, 212,215 chipset. Unfortunately I was notable to determine the producer of this board. I tried google image search, retroweb parametric search for CPU, CPU packaging and chipset, ebay but I have not got an exact match. Unfortunately the BIOS and the 8042 controller IC is missing. I have not got a canche to revive this MB if I donot know the type.
The component side has a sticker with "80 Data We develop technology" text. I was not able to reference this string. The revision string is 4.02 printed on the component side. The back of the MB has a production code of 90-30 and a "Made in Taiwan" text.
This is the first 286 MBoard in my hand and I do not have experience with these board.
To test this MB I am facing with the following issues:
1. I have not got experience with the 8042 controllers. I have to source a right one. Do they compatible to each other? I assume these chips should be compatible with each other to some degree independently from the manufacturer. But I do not know for sure. I have one 8042 IC for testing but if the MB accept only let say AMI type of 8042 than I have to source one.
2. Missing 41256 chips at the bottom - midle section marked as low and high. I am a bit confused: I assume the two bios chips should be here but the 41256 is referring a 32k static ram as far as I know. Should it be 27C256 instead of? If the marking is right than where are the bios?
Thank you your help in advance!
Reply 1 of 12, by Horun
The board is missing the 8042 KBC, the two bios chips (hi and lo) and the 286 cpu. Also needs ram, either 41256 or 411000 dips OR 1Mb 30pin SIPPS. Chipset says 16mhz but it has a 40mhz crystal,seems odd.
It looks very similar to a Protek board that someone was looking for info a few years ago but none was found iirc
Reply 3 of 12, by jakethompson1
For an AT-compatible 286 (like this) I do think you should be able to get away with any keyboard controller.
From what I've read they can get more specific when you get into thinks like PS/2 mouse, turbo switching through software (maybe you do care about that one), and especially, power management.
AMIBIOS will query the KBC to determine whether it's an AMI one, and if it is, append the KBC version number to the POST string at the bottom.
Reply 4 of 12, by mita
Thank you the replies! I am going to source the missing parts to move forward.
One question regarding the on board memory: how the SIPP memories can be used? Only SIPPs or the DIP memory chips separately or can it be mixed? If SIPP can be used alone than I would go to this direction instead of the DIP memories. Using the 30pin SIMM memory socket inserted into the SIPP socket would result an easier solution.
By the way I found the close "sibling" MB for this board. I am going to use its BIOS as a try. https://theretroweb.com/motherboards/s/caching-tech-cor-n286. There are some component placement differencies but it seems a close match. Some investigation will be needed to figure out the jumpers because the jumper configurations is quite different in my board.
Regarding the bios: it is a bit strange both files are 66KB size. I assume it should not be larger than 64KB burned into a 27c512 based on th DIP28 socket size. How the 66KB will fit into 64KB Eprom?
Reply 5 of 12, by wierd_w
weedeewee wrote on 2024-07-13, 21:08:
FYI the brand "Chips" 82C206 has nothing to do with the brand "pc chips" AFAIK.
correct, that is a Chips & Tech chipset.
https://en.wikipedia.org/wiki/Chips_and_Technologies
the chip in question is from the NEAT chipset. IIRC, there are utilities available to control this chipset to do arbitrary memory paging and shadowing in the adapter region, including EMS functions.
Yup, found it (them)
https://www.dosdays.co.uk/topics/neat_chipset.php
Reply 6 of 12, by jakethompson1
The datasheet (http://bitsavers.informatik.uni-stuttgart.de/ … Book_198710.pdf, p. 39) suggests that the chipset supports up to a maximum of 8MB memory, in four banks of 2MB each.
It takes 18 DIPs or two SIPPs to make one bank. So if you had all the DIPs filled with 1Mx1 chips, plus four 1MB SIPPs, you would have 8MB RAM. Unless this board is wired completely differently than that.
Reply 7 of 12, by mita
jakethompson1 wrote on 2024-07-15, 23:52:
Thank you the info. I ordered some DIM memories, Eproms, SIMM sockets for the SIPP and I have 1MB SIMMs. I will try out the expandability. 8MB in a 80286 MB? Incredible. What could be the price of 8MB at that time? About 1986-89?
Reply 8 of 12, by mita
wierd_w wrote on 2024-07-15, 23:47:
correct, that is a Chips & Tech chipset. […]
Thank you the info!
Reply 9 of 12, by weedeewee
mita wrote on 2024-07-16, 06:40:
You found 30pin simm sockets ? Care to divulge where ?
Do not ask Why !
Reply 11 of 12, by weedeewee
wierd_w wrote on 2024-07-16, 17:27:
Ebay has some reasonably priced (considering unobtanium new) NOS ones.
https://www.ebay.com/itm/122004729920
ah yes, I keep forgetting that sometimes they show up there.
Do not ask Why !
Reply 12 of 12, by mita
weedeewee wrote on 2024-07-16, 15:59:
The last item the SIMM socket on my shopping list. It seemed I will be able to get in within Hungary but it never happened. I could order from Italy on ebay but but it is turned out the solder pins of the SIMM sockets are too small in diameter and the connections with the SIP socket is very lousy. I decided to desolder some SIMM sockets from a donor board, desolder the SIPP sockets from the target board and replace them with the SIMM sockets.
I am not dare to start this soldering without a desoldering gun so I opened a side project to build one. I think this tool is one of the most important one for diy retro repairs. Diy beause it is fun. Buying is easy. Building and programming is a challenge.
