First post, by mita
Hi,
I got this 286 MBoard with PC Chips 82c206,211, 212,215 chipset. Unfortunately I was notable to determine the producer of this board. I tried google image search, retroweb parametric search for CPU, CPU packaging and chipset, ebay but I have not got an exact match. Unfortunately the BIOS and the 8042 controller IC is missing. I have not got a canche to revive this MB if I donot know the type.
The component side has a sticker with "80 Data We develop technology" text. I was not able to reference this string. The revision string is 4.02 printed on the component side. The back of the MB has a production code of 90-30 and a "Made in Taiwan" text.
This is the first 286 MBoard in my hand and I do not have experience with these board.
To test this MB I am facing with the following issues:
1. I have not got experience with the 8042 controllers. I have to source a right one. Do they compatible to each other? I assume these chips should be compatible with each other to some degree independently from the manufacturer. But I do not know for sure. I have one 8042 IC for testing but if the MB accept only let say AMI type of 8042 than I have to source one.
2. Missing 41256 chips at the bottom - midle section marked as low and high. I am a bit confused: I assume the two bios chips should be here but the 41256 is referring a 32k static ram as far as I know. Should it be 27C256 instead of? If the marking is right than where are the bios?
Thank you your help in advance!
