Rendition Verite Thread
Reply 740 of 805, by robertmo3
1GB memory stick on i5
Reply 741 of 805, by robertmo3
got cr and n2 working on a different socket AM2 mobo with single core Athlon 64 (1GB memory). I guess next step is to try Phenom on this board and A64 on the other board.
Reply 742 of 805, by sharangad
robertmo3 wrote on 2024-08-06, 07:29:
Can't wait for your results.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 744 of 805, by sharangad
robertmo3 wrote on 2024-08-08, 08:00:
a64 in the other board: cr and n2 still don't work.
phenom doesn't start in the other board at all (bios updated to latest):
https://www.msi.com/Motherboard/K9N_Neo_V2/support#cpu
Do you get the same error with the Phenom as in the other board? (Could not map physical to logic ...)
Reply 745 of 805, by robertmo3
exactly the same error on phenom and a64 on ASUS M2N-SLI Deluxe as yours:
Re: Rendition Verite Thread
Reply 747 of 805, by RaVeN-05
If someone here has a Heritage 16 MB V2200, can they check to see if the card actually reports 16 MB of VRAM?
Running RTest.exe from Windows 9x (https://nirvtek.com/downloads/RTest.7z) should report the amount of VRAM available to Windows.
Source Re: RReady (Rendition Verite wrapper) Test Build (Alpha 1)
P.S. Cross posted here.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 748 of 805, by sharangad
What I would like to see is someone running a replay using 1982Cart+DetroitDowntown on an 8 MB card and reporting back whether the world textures lose detail as happens here, towards the end:
https://youtu.be/fA5zMND9IHQ
1982Cart, paletted, no dither:
https://nirvtek.com/downloads/1982CART.Mi4.No … ditionReady..7z
MD5: 4090048745bcd2cc41e5908cf9d2a0aa
Detroit Downtown HQ:
https://www.icr2.net/forum/showthread.php?tid … =13943#pid13943
To install a car set, unzip carset contents to the cars/198cart subfolder. In game go to "Driver Info/Carsets" menu and select 1982 cart.
Install the Detroit downtown HQ folder by unzipping the track somewhere and copy the contents at the meaty level directory (not necessarily the blank higher levels) so that the files appear and paste them into <ICR2 folder>\TRACKS\Detroit91 .
Select the Detroit Downtown HQ track for a race and run 1 lap of a full race. Afterwards without exiting the track menu select replay and observer whether the world textures switch to a flat shaded single colour as the card runs out of texture RAM.
Reply 750 of 805, by sharangad
is it possible to run RRedline apps on a Creative 3D Blaster PCI?
I ask because I have a 3D blaster in a 2.4 GHz Pentium 4 Win98 machine. I can run RRedline apps with Rendition reference and Creative drivers, they're ridiculously unstable, usually crashing in Windows File Explorer.
The W98 built in drivers are stable, but there's no RRedline, Direct3D or OpenGL. But Speedy3D and CGL work fine. What's weird is that these drivers do have redline.dll and verite.dll but they don't seem to work for some reason.
Is this normal or is it just me? Thanks guys!
Reply 751 of 805, by RayeR
BTW I still wonder how many proprietary 3D APIs was there before OGL/D3D - just looking at thread about 3D Blaster and CGL. Can also V2200 run CGL games? If there's backward / driver compatability?
Reply 752 of 805, by sharangad
RayeR wrote on 2024-12-28, 15:50:
Nope, or not as far as I can tell. When my wrapper gets CGL support it might be a fun side project to try and get it going on the V2200.
Reply 753 of 805, by RaVeN-05
Welcome 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D)
Reply 754 of 805, by sharangad
I think I've fixed by RRedline problems on the 3D Blaster PCI. I had the machine connected to the network. Disconnected that and it's stable. There is one problem though, the monitor goes to "no signal" for around 30 seconds at Windows login. It might be my VGA to HDMI adapter, but the V2000 has no problems with that.
Reply 755 of 805, by RayeR
Btw what vga2hdmi you use? I tried a cheap one that even didn't pass textmode and anything below 480p as it had't scaler. I guess that even better adapters may not like some specific timings. You may pass video to old good CRT and put a remote streamed camera in front of it 😀
Reply 756 of 805, by sharangad
RayeR wrote on 2025-01-07, 14:48:
🤣! This one's quite good works really well with the Stealth II:
https://www.daraz.lk/products/vga-to-hdmi-con … XxoCSp4QAvD_BwE
Does all the console modes and everything. The only problem I have is with the 3D Blaster PCI at Windows startup. I actually get a warning from a piece of Creative software to update it right after the screen comes back to life.
[EDIT]
It used to work fine with the 3db as well before I updated the driver.
Reply 757 of 805, by sharangad
The RRedline Win98 instability I had with the 3D Blaster PCI was because I had Diamond's InControl Tools left over from the Stealth II S220. It wasn't because of network connectivity or the cpu being too fast (Pentium 4) or anything like that.
Everything's hunky dory after uninstalling that.
Reply 759 of 805, by sharangad
RaVeN-05 wrote on 2025-02-16, 10:48:
oh my god, i never thinks that way. so its easy solution
It didn't crash while running RRedline apps, but Windows explorer or just Windows would freeze with a moveable mouse. The Microsoft drivers that come with Win98SE worked just fine without RRedline support, but Speedy3D and CGL did work with it.
After zapping InControl, pretty much any V1000 driver, including Creative's own work without any problems. All 3 APIs are usable.
