First post, by Nemo1985
Hello good people, I stumbled upon a "rare" Abit bf6-2 revision 2.
The previous owner partially recap it but i noticed it has some 4 bulging capacitors behind the ps2 ports, so I'd go for a full recap.
The motherboards use the following caps:
7 10v 1000uf (the one which are bulging)
then near the cpu there are a mix of caps:
11 are 6.3v 1500uf
4 are 6.3v 1000uf.
I thought to go with those as for the 10v:
https://www.tme.eu/it/en/details/uhe1a102mpd6 … itors/nichicon/
While for the cpu area I'd go with polymer caps like those which are rated for 6.3v 1200uf:
https://www.tme.eu/it/en/details/a750ks128m0j … pacitors/kemet/
I'm puzzled about the kemet because they are rated just for 2000h.
There are those which are 1000uf only but rated for 5000h:
https://www.tme.eu/en/details/a755ks108m0jaae … rici-tht/kemet/
The alternative would be to go with nichicon:
https://www.tme.eu/en/details/upw0j102mpd/tht … itors/nichicon/
Or panasonic?
https://www.tme.eu/en/details/eeufr0j152l/con … -tht/panasonic/
Please advise.
Thanks!
