First post, by zb10948
Hello,
I'm trying to compile a list of programs and games that supported this mode.
So far I got
Microsoft Windows
GEM
Compushow
Zsoft PC Paintbrush
Microweb
Earl Weaver Baseball
I'd appreciate new entries to this list, especially games 😀
Reply 1 of 9, by Grzyb
https://ftp.math.utah.edu/pub/ibmpc/spwar171.arc
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 9, by Jo22
Hi there! ^^
From what I can remember..
- The Colony
- Psion Chess (1987 version, press "O" key in menu)
- MegaCAD 3.40
- Digi-Tech StarView (uses 1987 att.bgi driver, written in an Borland language)
- MS QuickBasic 4.5 (needs patch for generic hardware)
- Borland Turbo Pascal 4 with Graphix Toolbox
- Borland Turbo C
Edit:
- Geworks Ensemble ? (I'm using v2.0 on an 4,77 XT with CGA and V20)
- AT&T 6300 GWBASIC
- AutoCAD 2.5 or earlier ? (I read v2.53i started to drop older video hardware support)
- DataCAD 2 ? DataCAD Stories
- P-CAD ? (PCB software, 1986, supports strange gfx hardware such as IBM PGC; can load gfx drivers; check v4.5)
- Overhead Express 1.x ? (special version ?)
- PaintShow Plus 2.21
Reply 3 of 9, by zb10948
Hi thanks for responding!
For programming languages you listed I guess they have support in their internal graphics libs. I've been using Turbo C since forever and haven't bothered to check the BGI support. Nice that it has it.
Moby has some additional games - Space Battles, Checkers and Connect 4
Reply 4 of 9, by Starcat
This Usenet post to comp.sys.att from 1988 mentions several titles; Lotus 1-2-3, GEM, Windows, Pizazz, INSET, Turbo C, Turbo Pascal:
https://www.tuhs.org/Usenet/comp.sys.att/1988 … ber/004060.html
Hope that helps.
UNIX is a simple, coherent system that pushes a few good ideas and models to the limit.
Ritchie, D. M. Reflections on Software Research. Commun. ACM 27, 8 (August 1984), 758-760.
Reply 5 of 9, by doshea
"TinySol (formerly MonoSol) is a free tiny Klondike Solitaire game designed for good playability on vintage computers, especially those with monochrome screens."
https://classicbits.net/coding-and-software/m … ftware/monosol/ has the download and also a photo of it running in mode 40h.
Reply 6 of 9, by Grzyb
Derive has "AT&T" option - I guess it's the 640 x 400 mode.
Reply 7 of 9, by Jinxter
I tried Psion Chess version 213 (1985) but files was dates 1997 on Toshiba T3100e
Here are the pictures. I cannot see any difference in graphics.
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
Reply 8 of 9, by Jo22
Jinxter wrote on 2025-09-23, 17:57:
I second that, tried different versions in an emulator, too.
The detail level of the chess board and chess pieces didn't increase in Olivetti mode.
Why is that? Is it about missing graphics data or does Psion's Olivetti mode simply line double everything?
But then, what would be the point? The real Olivetti M24 used line-doubling all the time for ordinary CGA software.
Reply 9 of 9, by zb10948
No, that is pure CGA. In some occasions mode 0x40 compatible video cards stay in 640x200 mode but do something different than regular IBM mode 6. For example Prodest PC1 where it allows alternate character set, but still in 640x200.
