First post, by zb10948
Hello,
I'm trying to compile a list of programs and games that supported this mode.
So far I got
Microsoft Windows
GEM
Compushow
Zsoft PC Paintbrush
Microweb
Earl Weaver Baseball
I'd appreciate new entries to this list, especially games 😀
Reply 2 of 6, by Jo22
Hi there! ^^
From what I can remember..
- The Colony
- Psion Chess (1987 version, press "O" key in menu)
- MegaCAD 3.40
- Digi-Tech StarView (uses 1987 att.bgi driver, written in an Borland language)
- MS QuickBasic 4.5 (needs patch for generic hardware)
- Borland Turbo Pascal 4 with Graphix Toolbox
- Borland Turbo C
Edit:
- Geworks Ensemble ? (I'm using v2.0 on an 4,77 XT with CGA and V20)
- AT&T 6300 GWBASIC
- AutoCAD 2.5 or earlier ? (I read v2.53i started to drop older video hardware support)
- DataCAD 2 ? DataCAD Stories
- P-CAD ? (PCB software, 1986, supports strange gfx hardware such as IBM PGC; can load gfx drivers; check v4.5)
- Overhead Express 1.x ? (special version ?)
- PaintShow Plus 2.21
Reply 3 of 6, by zb10948
Hi thanks for responding!
For programming languages you listed I guess they have support in their internal graphics libs. I've been using Turbo C since forever and haven't bothered to check the BGI support. Nice that it has it.
Moby has some additional games - Space Battles, Checkers and Connect 4
Reply 4 of 6, by Starcat
This Usenet post to comp.sys.att from 1988 mentions several titles; Lotus 1-2-3, GEM, Windows, Pizazz, INSET, Turbo C, Turbo Pascal:
https://www.tuhs.org/Usenet/comp.sys.att/1988 … ber/004060.html
Hope that helps.
UNIX is a simple, coherent system that pushes a few good ideas and models to the limit.
Ritchie, D. M. Reflections on Software Research. Commun. ACM 27, 8 (August 1984), 758-760.
Reply 5 of 6, by doshea
"TinySol (formerly MonoSol) is a free tiny Klondike Solitaire game designed for good playability on vintage computers, especially those with monochrome screens."
https://classicbits.net/coding-and-software/m … ftware/monosol/ has the download and also a photo of it running in mode 40h.
Reply 6 of 6, by Grzyb
Derive has "AT&T" option - I guess it's the 640 x 400 mode.
Nie rzucim ziemi, skąd nasz root!
