SAB-2100 ISA Sound card
First post, by Noise_Unit
Hello fellow enthusiasts,
I am looking for information on this sound card of mine. Particularly its capabilities.
I can see an OPL chip but but I'm not sure about the rest of it. Looks like an IDE header?
Was pulled from a working Samsung Magic Station III SPC-8260P.
*Image not syncing because 31khz going to a 15khz*
The attachment 20240919_192816.jpg is no longer available
The attachment 20240919_192828.jpg is no longer available
The attachment 20240919_192838.jpg is no longer available
The attachment 20240919_200558.jpg is no longer available
Thanks!
Reply 1 of 9, by keropi
this card uses the OPTI 82C924 chipset that gives adlib/sb/sbpro/wss support and it has a real yamaha opl3
there is also the Dream SAM9203 wavetable synth on it with 1MB rom and ofcourse a CD-ROM interface (probably IDE)
there is a new Opti 924 driver here: Brand New Drivers for OPTI 82C929 and 82C924 including StereoFix , perhaps it will work better than the original one
Reply 2 of 9, by Noise_Unit
keropi wrote on 2024-09-20, 11:56:
Thank you!
Wow sounds like it's got quite a bit of support on it. Just missing GUS and Roland Intelligent support.
Am I correctly assuming the SB will handle the Roland UART?
Thanks for the help.
Reply 3 of 9, by Grzyb
There's room for two CD-ROM connectors: IDE, and Panasonic proprietary.
Only the latter is soldered in.
Yes, you can use Opti drivers.
For DOS, you can also use UNISOUND.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 4 of 9, by keropi
I stand corrected, like Grzyb mentions the interface is panasonic so not that useful
if everything works as it should then you should have midi in/out via gameport but keep in mind that the onboard dream wavetable will probably play at the same time as external midi
Reply 5 of 9, by gdjacobs
keropi wrote on 2024-09-20, 12:52:
Might be a mixer channel which can mute the onboard WT.
Reply 6 of 9, by keropi
Chances are wt is the same as opl - in some midi/music slider
Ofcourse you can mute in mixer but the game has to respect that and not change stuff - and history shows games do not respect such stuff 🤣
In any case Noise_unit will have to test things - perhaps onboard wt is tied to another input
Reply 7 of 9, by Noise_Unit
I will definitely test everything to my ability. Waiting on a 31khz monitor to arrive and see if there are any errors in the OS first.
Chances are there will be a Korean version of Win3.1 and or 95, possibly DOS. So I'll have to navigate that 😁
If the software doesn't respect the muting of the WT then this might not be a good candidate for future MT-32 support.
Reply 8 of 9, by Babasha
Noise_Unit wrote on 2024-09-20, 10:19:
Hello fellow enthusiasts, […]
Thanks!
Hi! Do you have any original drivers or utilities with your computer?
Need help? Begin with photo and model of your hardware 😉
Reply 9 of 9, by Noise_Unit
Unfortunately I do not! Using UNISOUND to initialize the drivers 😀
