First post, by Mondodimotori
- Member
Since the Socket A build is on hiatus until I get the Enermax back, I've decided to start looking into the 370 build, and I have a doubt that I wasn't able to clear by surfing this forum and the wider net.
I have a QDI Advance 10E, a full ATX socket 370 mobo that supports up to Coppermine Pentium III (by the manual itself). Nice mobo, with AGP slot and several PCI slots.
Currently it has a Celeron 700, wich is pretty slow with the OS installed, Windows 2000 (I may convert it to a 9x build if the socket A machine keeps being more headaches than else), and I wanted to upgrade it to a Pentium III 1000.
What I've read is that Pentium IIIs up to Coppermine have the die exposed and no rubbery thingies (like Athlon and Duron) to help with the cooler installation, thus making it much easier to crack the die and kill the CPU.
So I was looking at Coppermine T processors, wich should still be fully compatible with the mobo, and the heatspreader can help with installing the cooler safely. But since the IHS is taller, I was wondering: How does this affect cooler compatibility and pressures on both the CPU and the socket itself?
I alredy have a standard cooler on the machine, and I think it should be enough to keep it cool (the sensor on the mobo appears to be busted, since it always report 51° no matter what, even in BIOS at first cold boot). I also have a couple of spare A/370 coolers that I got just in case for my Athlon. And I wanted to make sure that, if I take the Coppermine T option, I won't have problems with overstressing either the CPU or the socket, since these coolers attach directly to the plastic clips on the socket itself, and the slightly taller CPU may put more stress on them.
Or I could also use the current Celeron 700 as a training tool and spend a couple of hours removing and reinstalling the cooler until I can do it perfectly, and then just get myself a Coppermine without IHS, since they're also cheaper on the used market than Coppermine T.
What are your thoughts and/or experiences on the matter?
