Is this a good card??
First post, by Cursed Derp
Heyyyyyyyyyo,
I need to get some info on this card. Is it any good?
https://www.ebay.com/itm/135193526284?_skw=ra … ABk9SR579ua7OZA
Is it a rage 128 pro or fury?
Any help would be greatly appreciated.
Thanks
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 1 of 20, by chinny22
It's all 3, ATI gave the exact card 3 different names.
Rage 128 Pro
Rage Fury Pro
Rage Fury MAXX
Card is ok,
You can read more about it on vogons wiki
https://www.vogonswiki.com/index.php/ATI#Rage_128_Pro
And here is a more recent discussion on the card
ATI Rage 128 Pro - Better than expected!
The "better then expected" sum's its up pretty well. I have a Celeron 400 that lacks AGP but has this onboard, It's a budget offering, keeping in mind its low cost it isn't that bad but it's nothing special either.
Reply 2 of 20, by VivienM
What system do you want to put it in? And what do you plan to use this system for?
Reply 3 of 20, by Horun
I am going to answer as an avid gamer back in late 90's thru 2010 because I was. Stay away from ATI Rage based, back then every time a new game came out ATI released a new driver for every major game or else the game had issues with their cards.
Got bad enough ATI changed the name of the a few times but still same issues.. (wonder why it has Rage 128, Rage Fury, etc for same branch of development?)
What was worse is that every time they did that it made some previous game have issues. All my gamer friends gave up on them and moved to Nvidia based which had so much less issues..... just my opinion from experience.
added: Nvidia also had some issues but nothing like ATI at that time....
Reply 4 of 20, by dormcat
chinny22 wrote on 2024-10-10, 02:55:
It's all 3, ATI gave the exact card 3 different names. Rage 128 Pro Rage Fury Pro Rage Fury MAXX […]
Rage 128 Pro
Rage Fury Pro
Rage Fury MAXX
IIRC Rage Fury MAXX had a dual-chip design: https://www.techpowerup.com/gpu-specs/rage-fury-maxx.c644
They all shared the same chip though, just with different clock speeds, memory types, bus width, etc.
VivienM wrote on 2024-10-10, 02:57:
I'd bet a Dell Dimension 4100, with the intention to replace the Dell OEM TNT2 M64 that came with the system.
Cards of Rage 128 PRO family had comparable raw performance to TNT2 M64 but had much more driver issues.
Reply 5 of 20, by leileilol
NOTE: a fury can also be a not pro and just a plain Rage 128. Fury is a marketing name and it is not exclusive to the MAXX. There was just a thread about this.
The Rage 128 Pro / Fury Pro did have advantages like texture compression and better 32-bit and trilinear over the TNT2 so that's something to think about. Does futureproof it a little bit more. Also the dithering table sucks less 😀
Debian's fucked
Reply 6 of 20, by appiah4
Rage 128 Pro
Rage Fury Pro
Rage Fury MAXX
Card is ok,
This is incorrect, the Fury MAXX is a completely different, dual GPU card..
Reply 7 of 20, by kixs
I'd skip this low end cards. Go for at least some Geforce4 MX to Geforce Ti4200. Depends on your budget of course. But with some luck you could find a good deal.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 8 of 20, by The Serpent Rider
This one is actually really good for what it is, because it's a low-profile Rage 128 Pro with fully functional 128-bit memory bus. It's the fastest card of 1999 for SFF.
Reply 9 of 20, by kixs
I guess he doesn't need a SFF card.
It's one thing if he is looking for a specific or period correct card, but another if he wants something that works good. It's better to spend 20-30USD more then buy something cheap and later replace it anyway.
Found a similar topic:
Dell Dimension 4100 with ATI 9800 Pro/Windows ME or 98SE?
Reply 10 of 20, by Cursed Derp
Yeh it's Dell Dimension 4100
Reply 11 of 20, by Cursed Derp
Horun wrote on 2024-10-10, 03:37:
I am going to answer as an avid gamer back in late 90's thru 2010 because I was. Stay away from ATI Rage based, back then every […]
So it's not only all basically the same card, it was amd trying to erase their driver history... dammmm
Reply 12 of 20, by Cursed Derp
kixs wrote on 2024-10-10, 09:28:
I guess he doesn't need a SFF card. […]
I do want period correctness tho
Reply 14 of 20, by VivienM
dormcat wrote on 2024-10-10, 05:08:
I know that the TNT2 M64 is uncool and all, but... I had a Dell one back in the day, it worked fine, drivers were solid enough to stay out of the way, it even did some acceptable enough gaming. Not a bad card if you couldn't afford better.
And certainly... much less likely to cause trouble than ATI's cards at the time.
Reply 15 of 20, by VivienM
Cursed Derp wrote on 2024-10-10, 12:30:
Okay, so if you want period correctness, the top of the line option at the time of a Dimension 4100 was a GeForce 2 GTS. Maybe a GeForce 2 Ultra but I am not sure Dell offered (and I presume with all of Internet Archive's recent issues, I can't check wayback machine) those. eBay is also full of Dell OE GF2 MX cards.
I really, really would urge you to stay away from ATI. In part because ATI had a different philosophy when it came to drivers in those days - they had separate drivers (with separate bugs) for each of their products. Nvidia had one driver family, which I think was called... Detonator... back then, so they would release updated drivers for the entire product lineup quite regularly. ATI would eventually embrace the Nvidia-style model with the Catalyst driver family on the later Radeons, but I don't think that applies to the cards you're looking at.
Reply 16 of 20, by Cursed Derp
VivienM wrote on 2024-10-10, 15:35:
Okay didn't know ATI was that bad
Reply 17 of 20, by leileilol
ATI kicks nvidia's ass because they don't sabotage PowerVR cards (in the drivers or in the market and otherwise). 😀
also before anyone brings up the old 'ati suck's at opengl It is a shit grafik' quake3 bars - r_primitives, everyone. The same CVA detection glitch bit back at nVidia years later.
Debian's fucked
Reply 18 of 20, by appiah4
Cursed Derp wrote on 2024-10-10, 17:34:
That's fine, because they were not bad. At all. I've been using ATI cards and drivers since Radeon 8500 and it was just FINE. And ATi did have unified drivers all the way back in 2002: https://www.anandtech.com/show/931/2
Reply 19 of 20, by kixs
Cursed Derp wrote on 2024-10-09, 20:12:
Heyyyyyyyyyo, I need to get some info on this card. Is it any good? https://www.ebay.com/itm/135193526284?_skw=ra … ABk9SR579ua7 […]
Heyyyyyyyyyo,
Thanks
Somehow I got an offer from the seller just by looking the ad once. Maybe you got it too. Discount is pretty good so you get the card for cheap...
