First post, by fsinan
Lucky Star LS-486E board with 256K cache
AMD 5x86ADZ at 160Mhz.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 1 of 13, by Tomek TRV
So You have 4x40MHz. I think that it would be interesting to try 3x50MHz. CPU will be 10MHz slower but bus will be faster.
Reply 2 of 13, by analog_programmer
Hmm, I don't want to crush your enthusiasm, but the result seems equivalent to the reference AMD Am5x86-160.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 3 of 13, by fsinan
analog_programmer wrote on 2024-10-13, 18:35:
How many people have a stable 160Mhz AMD 5x86?
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 5 of 13, by leileilol
fsinan wrote on 2024-10-19, 05:32:
*raises hand*
Ironically I couldn't get a stable 150mhz. don't recommend 3x50
Debian's fucked
Reply 6 of 13, by PD2JK
Me too. Nevertheless it's fun to OC and play around with this stuff. 50 MHz bus speed is indeed a challenge, the ISA/VLB/PCI bus will also operate at this frequency, so all devices connected to the bus are challenged. Not to mention you'll need super fast cache SRAM it can cope with.
Vote for 4x 40.
has all kinds of stuff
Reply 7 of 13, by Many Bothans
PD2JK wrote on 2024-10-19, 12:40:
It's all good fun, 40x4 is the sweet spot with my AP43.
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32
  • ITX-Llama, 3Dfx V3
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 8 of 13, by GigAHerZ
I keep my 486 @ 3x50MHz. Yes, i couldn't use the absolute tightest timings on cache and ram though. But in the end, i truly enjoy the Trio32 memory bandwidth that comes with 50MHz VLB. (I refuse to use PCI on a 486)
Reply 9 of 13, by BitWrangler
I will have to try my DX4-120 at 150, then I'll have a fast 486 that actually says 486 on it. Though there's some stealth DX5 DX4s around that will probably do better.
Reply 10 of 13, by Tomek TRV
I have 3x50MHz but it is not completely tested. I just build this machine, run some tests from Phils Computer Lab package which worked fine and I left it because I am working far from home and don't have much free time. I have some suspicions that it may be unstable because I don't have correct VRM for my motherboard and I am using cheap step down converter from aliexpress. This is another project to do - create good VRM but I have so many opened projects that I don't know when I will finish it, maybe on retirement.
Reply 11 of 13, by H3nrik V!
I had back in 1999, but I'm not sure if my criteria back then for "stable" were as strict as they would be today 🤣
Reply 12 of 13, by tauro
It's the go-to overclock for this chip without raising the voltage. As other user mentioned, 3x50 is also a nice alternative to run a faster bus. And if you like to push it, some can do 60x3 (4v). It depends a lot on the motherboard and your video card.
Back to the Am5x86@160MHz, it's crazy fast for all things DOS. In some things faster than an early Pentium. Even Win9x runs decently (95 is better). It's only surpassed by a Cyrix 5x86 or a Pentium Overdrive. But those aren't exactly 486 chips.
Reply 13 of 13, by Unknown_K
I have a 160 (4x40) that was overclocked since the 90's on a PCI motherboard. It was common back then to do this because it gave you early Pentium speeds without the cost.
