meljor wrote:My acer ap43 pci board will not take it. This board is known here to run it just fine but mine has a slightly older bios and as soon as i jumper it to enable the 4x multi it acts really strange and extremely slow (cache not working).
Running it with slower timings and 3x50 is no problem and almost equal to 160mhz .40fsb gives a bit better timings ofcourse but 3x40 is still slower than 3x50.
So if it is not running properly try the dx4 setting with 3x40 or 3x50. The 16kb cache alone will make it faster than the dx4-100@120.
I very vaguely remember having used a DX4 in my Acer AP43 instead of a 5x86 and apparently it can be a tricky board on which to get the 5x86 running properly...or running at all even.
RacoonRider send me some undocumented jumper settings along with an explanation on how to get a 5x86 running on an AP43 a couple years ago.
I never got around to try these out for myself though, but for the AP43 this might be worth a try and I might as well spread this bit of info in case anybody might ever need it.
_________JP25____JP26
25 MHz___2-3____2-3
33 MHz___1-2____1-2
40 MHz___1-2____2-3 <unlike the manual/th99/PCB prints
50 MHz___2-3____1-2 <not stated in manual
and
The jumper settings are described on page 15-2 of the second part of the manual. However, if you just set it up, nothing will work or even POST! You have to set jumpers for DX4 SL-enhanced WB first, start the system, and only then turn it off and add JP12. I have now idea why it does not work otherwise, I triple-checked everything and still no post. You have to do this only once though.
The EXP-4045 might have undocumented jumper settings as well?
Btw, I recall some people actually managing 200MHz with the AMD 5x86 part, but those might've been some of the more recently manufactured parts.
