First post, by THEBaratusII
- Newbie
Last month, I got myself two AT form factor PCs, both with AMD K6-2 processors. One with 350MHz and the other with 550MHz.
My original intent for this machine would be for Windows 98 gaming, but since the VIA chipset refused to install that. I did more thinking and I thought about a Windows NT4 or Windows 2000 environment? I mean not the greatest for gaming but I could imagine it would be fun to mess around with especially when tinkering with Windows programming despite having little to no programming knowledge. But again I could just keep Windows Me on there. The name I gave it should suggests using the Super Socket 7's capabilities.
The system specifications I am aiming for :
DFI K6BV3+/66 (Super Socket 7 Motherboard)
VIA VT82C598 (Apollo MVP3) Chipset
AMD-K6-2/550AGR (350MHz was on this board previously)
128MB SDRAM (100MHz, Single Module)
SiS 6326 8MB, AGP 2X * May upgrade to a 3dfx card later down the line *
Sound Blaster AWE64 Value
3Com EtherLink III ISA (3C509b-TPO)
Parts that I was considering
Diamond Viper V550 (NVIDIA RIVA TNT) 16MB, AGP 2X (Swapped out with SiS AGP card to prevent issues?)
YAMAHA OPL3-SAx ISA Sound Card
Now of course the case I will be using is shown as an attachment but I need to sort out the disc drives as they both get stuck when ejecting and need to look into fixing them. As for the hard drive, I got some spare IDE HDDs I could try out. Not only that but I am going to attempt using an ATX power supply since the mobo has both AT and ATX power connectors but I will be lacking a power switch unless I get myself an adapter/switch.
Will update when I make progress.
