First post, by THEBaratusII
Last month, I got myself two AT form factor PCs, both with AMD K6-2 processors. One with 350MHz and the other with 550MHz.
My original intent for this machine would be for Windows 98 gaming, but since the VIA chipset refused to install that. I did more thinking and I thought about a Windows NT4 or Windows 2000 environment? I mean not the greatest for gaming but I could imagine it would be fun to mess around with especially when tinkering with Windows programming despite having little to no programming knowledge. But again I could just keep Windows Me on there. The name I gave it should suggests using the Super Socket 7's capabilities.
The system specifications I am aiming for :
DFI K6BV3+/66 (Super Socket 7 Motherboard)
VIA VT82C598 (Apollo MVP3) Chipset
AMD-K6-2/550AGR (350MHz was on this board previously)
128MB SDRAM (100MHz, Single Module)
SiS 6326 8MB, AGP 2X * May upgrade to a 3dfx card later down the line *
Sound Blaster AWE64 Value
3Com EtherLink III ISA (3C509b-TPO)
Parts that I was considering
Diamond Viper V550 (NVIDIA RIVA TNT) 16MB, AGP 2X (Swapped out with SiS AGP card to prevent issues?)
YAMAHA OPL3-SAx ISA Sound Card
Now of course the case I will be using is shown as an attachment but I need to sort out the disc drives as they both get stuck when ejecting and need to look into fixing them. As for the hard drive, I got some spare IDE HDDs I could try out. Not only that but I am going to attempt using an ATX power supply since the mobo has both AT and ATX power connectors but I will be lacking a power switch unless I get myself an adapter/switch.
Will update when I make progress.
My Website
YouTube Channel
Reply 1 of 13, by Repo Man11
In such cases I've always used the reset switch as the power switch.
Assuming that it is the usual aged belt that is causing the optical drives to malfunction, I've had some success by scrubbing the drive side of the belt with a Scotch-Brite pad to take off the hardened layer that slips, but replacing the belts with some generic ones I bought on Amazon has proven to be a better long term fix.
Reply 2 of 13, by THEBaratusII
Repo Man11 wrote on 2024-10-03, 16:43:
Perhaps that could work, I should give that a try sometime. I thought about opening up the disc drives to troubleshoot what may be the problem. Will consider checking out the belts at some point as well.
I might start working on the machine on Sunday.
My Website
YouTube Channel
Reply 3 of 13, by melbar
THEBaratusII wrote on 2024-10-03, 16:26:
128MB SDRAM (100MHz, Single Channel)
You mean single module, right?
The signal words, single channel and dual channel come to the PC user market with AMD's nforce2 and intel's i865 chipset.
Even my fastest Win98 build with a P4 2.8 Ghz cpu (and can be clocked easily to 3Ghz), has single channel DDR ram only...
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 4 of 13, by ratfink
Windows 98 ought to run on this. Did you try the VIA 4-in-1 drivers? My PA-2013 was awful (also Super 7 with VIA chipset) until I installed those.
Reply 6 of 13, by THEBaratusII
ratfink wrote on 2024-10-04, 23:56:
I recall before I got around to installing the chipset drivers, I ran into this problem while trying to install 98SE.
On another note, I got most of it built but I am kind of stuck on getting the machine fired up with a modern (Coolermaster PSU) ATX power supply. I put it aside for now as I am working on a video, but sometime later on I will get back to it and see if I used plugged the reset switch in the wrong pins or maybe the power supply is having issues itself.
My Website
YouTube Channel
Reply 7 of 13, by THEBaratusII
So a bit of small progress several days back. The Coolermaster power supply still works thankfully, so I managed to find the right pin to hook the reset switch into (thanks screwdriver!) and it manages to boot. For some odd reason, my existing install of Windows Me got corrupted. Maybe has something to do with my molex cable route. I had the hard drive plugged in on the molex cable that was splited between that and the CPU fan that came from the heatsink.
I do plan on trying Windows 98SE again and will be swapping out the TNT card with a SiS 8MB card to avoid potential AGP issues. To further explain, while I was playing a MS-DOS game (Blood, 1997) under Windows Me, the sound would suddenly stop working after a little while of playing which led to me moving my playthrough (been streaming my playthrough on YouTube) to my Pentium II 400MHz machine. As for potential upgrades for RoidRage, I aim to likely save up enough money for a 3Dfx card (possibly a Voodoo 3/Velocity or a Banshee?) either as a AGP or a PCI card. Though I am on a shortage of PCI video card in general.
From what I've learned from others and a friend of mine, the AMD K6-2 machines were quite frustrating to work with and usually the wrong hardware and settings can be enough to cause instability. I do however have a PC Chips Super Socket 7 motherboard for another project, most likely aiming to be a Pentium MMX machine. Anyway will report back sometime on how installing Windows 98SE ends up.
My Website
YouTube Channel
Reply 8 of 13, by thp
You can modify a toggle switch to be a momentary switch. There‘s a small piece of metal in the switch that hooks the switch in place, and if you remove it, you turned your AT style switch (latching) into an ATX style switch (momentary).
Might be worth a shot to avoid buying a small piece of equipment assuming you have an old AT power supply you can use the switch from for parts.
Reply 9 of 13, by H3nrik V!
THEBaratusII wrote on 2024-10-14, 05:03:
From my experience, it's not due to the AMD CPU but quirks in the chipsets on many SS7 motherboards ..
Reply 10 of 13, by THEBaratusII
H3nrik V! wrote on 2024-10-16, 04:04:
Ah I see. Though I may end up trying another power supply because for some weird reason, both the CD and Hard Drives don't seem to be powering properly. Sometimes one of them would detect or both would detect but not properly, which explains why Windows Me wasn't booting up correctly. As for what spare power supply I may end up using, I'll have to figure it out, worst case scenario I could end up using the only working AT power supply that has an actual AT switch. I do have another one from an old Compaq but idk if that would work because it doesn't have the AT power switch.
My Website
YouTube Channel
Reply 11 of 13, by THEBaratusII
It has been about a few months, so I might as well share an update. I believe my priorities have changed since the previous post and I am currently using the motherboard from the OP inside another case to use as a Windows Me machine. The machine has been underclocked from 350MHz to 233MHz mainly to play some speed sensitive games. Now I did however test the PCChips motherboard a while back but I believe the ISA slots has issues when in-use causing it to no longer POST. I plan to look into finding another Socket 7 motherboard and another power supply before I continue the RoidRage project while also getting around to build a regular Pentium machine most likely.
That's about all I can share at the moment, but it'll take awhile before I can continue this project.
My Website
YouTube Channel
Reply 12 of 13, by Intel486dx33
I have mine installed with Win98se
I then installed SP3 core updates
Reboot
Then install Directx 9 from SP3 optional updates
Also I have 256mb of SDRAM PC-133 for best performance
My Computers running K6-3+@550mhz are Very Stable and Reliable
Reply 13 of 13, by marxveix
I have K6-2+ with VIA MVP3, all works, i used 4in1 4.17 / 4.23 or agp driver 405b as i remember and i never had issues @Win98SE installation.
I dont use any Service Pack for Win9x 😀
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
