Reply 54760 of 58196, by marxveix
Retro case: Arctic Cooling Silentium T Pro
Cooling solution is different than most of the cases out there.
This Arctic Cooling case best to use with longer GPU (graphics)?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 54761 of 58196, by myne
That psu fan looks like a screamer
I built:
Reply 54762 of 58196, by Wes1262
The form you submitted was invalid..... not really.
Reply 54763 of 58196, by Wes1262
Got the card and here's the pics. Haven't tried it yet. Crossing fingers.
Is it a ti500 in your opinion?
Reply 54764 of 58196, by zuldan
Wes1262 wrote on 2024-10-17, 11:25:
Got the card and here's the pics. I still haven't tried it. Crossing fingers.
Thanks for that. Looks my transistor has 100% been blown off . On the rear of the card, bottom right hand corner. Does the transistor Q200 have any labeling?
Reply 54765 of 58196, by Wes1262
zuldan wrote on 2024-10-17, 11:28:
Thanks for that. Looks my my transistor has 100% been blown off . On the rear of the card, bottom right hand corner. Does the transistor Q200 have any labeling?
My eyes are old and tired but I am fairly sure nothing is written on it.
Reply 54766 of 58196, by marxveix
myne wrote on 2024-10-17, 11:09:
Arctic Cooling fans are not screamers, but still there are many small fan-s (not ideal). It should come with 500w (490w) psu (seasonic i think).
Reply 54767 of 58196, by PcBytes
From both your thread and a few pics, it should be a 1P transistor, namely a PMBT2222A.
Reply 54769 of 58196, by PcBytes
They're the same thing.
Reply 54770 of 58196, by zuldan
PcBytes wrote on 2024-10-17, 11:50:
Fantastic, that’s what I figured. It should be arriving tomorrow. The fan will be running again hopefully.
Reply 54771 of 58196, by AGP4LIfe?
Trashbytes wrote on 2024-10-17, 09:02:
Unknown_K wrote on 2024-10-17, 06:51:
There are people who were infants when 486 systems were being sold and they still buy one for retro gaming.
Generally anything high end gaming of its day will probably keep getting more expensive as time goes by because of demand and working supply. 3DFX will always command a premium because of GLIDE games.
I didn't know ATI Furry MAXX were $400 these days, I didn't bother with one when they were 1/10 that because they kinda sucked new.
They are higher now, they are rather rare and even more so in working condition, many of the ones you see on Evilbay are "not working or for parts" for a reason.
Many sellers from eBay, do not even test their parts and list them as "used" "working" "tested" Its actually quite annoying.. Its apparent within 5 seconds after plugging it in that they didn't test it. One of the dead giveaways is even before you plug them in, depending on how stiff the fan is with just a finger push, you know whether card will have a 75% of being dead or not.
Grrr...
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54772 of 58196, by Wes1262
Yeah sometimes the fan is so stuck it makes death noises for a good 10 minutes before the oxidation gets scraped away. At best they turn on the card and see if it posts, but thats also rare.
Reply 54773 of 58196, by Babasha
Rare? 😉
Need help? Begin with photo and model of your hardware 😉
Reply 54774 of 58196, by Tiido
I had one of those, it served me well until one day the northbridge died of overheating... The winbond PCI to ISA bridge has some IRQ jitter and you may get scratchy or click filled audio in some games and some sound card combinations...
LIke mine, it needs all new capacitors, some already have bulged... The ones near CPU will all burst (Nichicon MH series IIRC).
Reply 54775 of 58196, by zuldan
What motherboard is that?
Reply 54776 of 58196, by Wes1262
So it was indeed a Ti500. PHEW
It could run a full 3dmark 2001, but it might have some problems. The monitor kept adjusting between each 3dmark test. With both DVI and VGA.
Maybe I should try different drivers?
Reply 54777 of 58196, by Babasha
zuldan wrote on 2024-10-18, 05:51:
Full info
Reply 54778 of 58196, by digger
BetaC wrote on 2024-09-17, 23:18:
Today I picked up a goofy little guy. […]
The attachment IMG_3940.jpg is no longer available
The attachment IMG_3941.jpg is no longer available
I'll probably never use it, but I can't help but think it's neat.
I remember trying to use an adapter like that when I upgraded to a newer motherboard, in an attempt to reuse my 30-pin SIMMs in a motherboard that required 72-pin SIMMs.
Unfortunately, it didn't work, so I had to get actual new SIMMs instead. I have no idea whether the adapter was defective, or just not compatible with some motherboards. 🤷🏽
Reply 54779 of 58196, by AGP4LIfe?
Wes1262 wrote on 2024-10-18, 06:07:
I would definitely try a different driver, that is a really late XP driver. For perspective the 8000 series had just launched. That's a 5 generation spread from the GF3.
At most I'd use 71.89, but would probably be better served in the 56.xx's.
